XLT Console Questions..
Old Apr 5, 2006 | 07:20 PM
Ascii's Avatar
What size torx do I need to get the seat style console out??
Are there any mounting brackets needed for the XLT stand alone console?
What is the best way to clean interior parts that are pretty dirty?? Soap and water only is what I was planning on using but if anyone has any better suggestions they are appreciated.
Thanks in advance..
Old Apr 5, 2006 | 09:07 PM
05RedFX4's Avatar
IIRC you need a T-50 torx bit for the seat bolts. You don't need any extra brackets to install an XLT console where the center 20 section used to be, it uses the same holes that the seat used. The install should take you about 10 minutes more or less, depending on how it takes you to down a six pack while your working. Post pics when your done.
