Edge Came today! Cpl of ??'s
Old Apr 4, 2006 | 08:46 PM
mkinttrim's Avatar
Just have it on level 1 as I still have 85 octane in the tank, can't wait for Level 2. Anyhow where do I find spray paint to paint the pod, does Ford have this? I need either tan or preferably light brown. What is the correct tire size in mm for a stock 265/70/17 ? Just gonna run the stock tunes for a while then I'll be tweeking it a little later. I'm at 5800 ft and was told that I should advance the timing to +2, is that about right? Ant other hints would be appreciated.
Old Apr 4, 2006 | 08:56 PM
kanter's Avatar
Do a search. There was a big thread about painting the pod.
Old Apr 4, 2006 | 08:57 PM
KiCk aSs FX4's Avatar
have you uploaded the new software form the website? it is pretty useful for finding out your horsepower and other ratings. You can also download the updates with it.
Old Apr 4, 2006 | 11:46 PM
mkinttrim's Avatar
Yes, downloaded latest update B4 I installed it. Do you have to return setting to stock if you removed it? Thought I read somewhere that you need to return to stock B4 you do something but can remember it was and the manual doesn't mention anything from what I saw.
Old Apr 4, 2006 | 11:54 PM
Doo2theSea's Avatar
YES - If you are removing it to update it you need to always return to stock. You have the option of just programming the PCM and then removing it though but who wants to do that with all the nice gauges!!
Old Apr 5, 2006 | 12:17 AM
nvrenuff's Avatar
so your running the level 1 trans program only? Why? You can run level 2 without a problem using 85octane, level 2 is designed for 87octane and at your altitude, you won't get any detonation. Of course, always listen for it anytime you put in a new program you haven't tried before.
Old Apr 5, 2006 | 10:10 PM
mkinttrim's Avatar
Your right, running level 2 now on 85 octame and not a problem at all. Difference between night and day!
