Accurate Conversions - Backspace / Offset
Old Apr 3, 2006 | 01:00 PM
sirshan's Avatar
I tried this in the Wheel and Tire section and got some replies, but I want to make sure that everyone comes up with similar numbers.
For those gurus that KNOW how to convert...please do the following conversion from Offset to equal Backspacing.
20x8.5 with a +35mm Offset
20x10 with a -24mm Offset
Lets see the numbers. Ive had 3 different #'s and just want to compare what you all come up with.
Thanks.
Old Apr 3, 2006 | 01:11 PM
BalogUK's Avatar
20x8.5 w/ +35mm= 5.627" BS
20x10 w/ -24mm= 4.056" BS
thats what i figure anyways...
Old Apr 3, 2006 | 01:42 PM
sirshan's Avatar
How do you get those #'s?
With the 20x8.5 Im told it would be somewhere around 6.1" of backspacing?
This is where Im getting confused...not that its bad...Im just looking for an accurate figure.
Here is one method I found:
TO CONVERT OFFSET TO BACKSPACING:
For positive offset wheels: (Wheel Width +1)/2 + (offset * .03937)
For negative offset wheels: (Wheel Width +1)/2 - (offset * .03937)
Thats from Mickey Thomsons site I believe.
Old Apr 3, 2006 | 02:04 PM
BalogUK's Avatar
this is how i figured:
offset is the distance from center so...
20x8.5
so center is 4.25"
+35mm= +1.377 inches
4.25+1.377= 5.62"
20x10
center is 5"
-24mm=-.944 inches
5-.944=4.056 inches
edit to add- i can see where they are getting 6.1" though- went and found your mickey t site, and did some reading...they are adding 1" due to the rim lip--- that rim lip varies from mfr to mfr- sooo...if i add .75" (i think 1" is alot) and then do the same math as listed above, the 20x8.5 has 6" BS
and the 20x10 has around 4.4-4.5" BS
Old Apr 3, 2006 | 04:28 PM
sirshan's Avatar
Yeah, I noticed that...
Thanks for the help...whichever one is right...they will both work with the Rancho Lift Im getting anyways. If not...it will still work at stock height as well.
Old Apr 3, 2006 | 06:24 PM
Dog'em's Avatar
According to the chart on BigCustomRims.com the
20 x 8.5 with +35 = 155 mm or 6.1" backspace
20 x 10 with -24 = 115 mm or 4.5" backspace
So far all of the wheels that I have researched this chart has been dead on.
Good luck.
Old Apr 3, 2006 | 09:58 PM
sirshan's Avatar
That sounds right...whats the site? I cant seem to get to it if thats the exact address.
Old Apr 3, 2006 | 10:14 PM
Dog'em's Avatar
Sorry about that, was kind of in a hurry. Try this address and go to the "Sizes Guide". Really a cool chart for figuring tire and wheel sizes along with back space and offset. Like I said before, it seems to be pretty accurate.
www.bigcustomwheels.com
Old Apr 3, 2006 | 10:21 PM
sirshan's Avatar
Very useful and awsome site to use...that one is definately bookmarked. Thanks!!!
