safety hook replacement
safety hook plate replacement
I bent the plate on my trailer hitch where you connect the two saftey chains pulling someone out of the mud...has anyone ever replaced this plate and if so where can you purchase one...also has anyone ever taken this plate off and put a heavier duty plate or some other kind of mod that would take more of a beating? Thanks in advance...Jeremy
a big hammer should do some good, as long as none of the welds look cracked
check this out, a good read for anyone that MIGHT be pulling some one out in the future
http://www.oramagazine.com/pastIssue...ue/finesse.asp
It probably would cause it to be weaker but if he doesn't try pulling people out of the mud with it then it probably won't hurt anything. You should get one of these
http://cabelas.com/cabelas/en/conten...520417sq01.jpg
or one of these
http://cabelas.com/cabelas/en/conten...520052sq02.jpg
or one of these
Originally Posted by The professor
..<snip>...You should get one of these
I like the looks of that Warn one better, but too late now...
I think I'm going to invent an aerodynamic skidplate that splits mud rather than pushes over. It's definitely an idea and it's used today on the bases of bridges for ice protection. Whose with me
Definetly take it down to your local welding shop. It'll be much more expensive to replace the whole reciever mount, you can probably get it fixed and reinforced for $50 locally, if they charge you that much. As long as you just bent the safety chain mount, it shouldn't be any big deal at all. But get a square and get underneith your truck and make sure the reciever mount isn't tweaked at all too, thats a much bigger deal.
