RCD 6" Installed w/ pics
I just installed RCD's 6" kit. This was a lot of work, but it was worth it in the end. Toyo 325/65-18 on Eagle 064 18x10 with no rubbing! I did have some problems with RCD instructions giving wrong directions though. Cost me about 2-3 hours extra work because they have a bracket going in the wrong way according to the instuctions.
Before:
After:
https://www.f150online.com/galleries....cfm?gnum=7244
Before:
After:
Looks great, what were the required tools and what was the absolute bare minimum you needed to install it? Also, how long did it take.
Justinman - Truck looks sweet. It makes me mad to look at though because I also have a black super cab too. I like those fender flares; are they the Bushwacker Extend-A-Fender's? I prefer them over the pocket style.
Your tires equate to 34.9" x 13.3". Do you see a problem fitting 36.3' x 12.8" tires on your truck?
Many metric sockets and wrenches were used to install the lift. The coil spring compressor I had didn't work, so I had to take the strut assembly to a local shop and have the struts swapped out. The frame has to be cut, so a small grinder was needed too. The lower strut bolts had to be torqued to like 350lbs, so I had a huge torque wrench.
The lift and running around town took me all of 2 days plus some. It was not a quick deal, but I was working with the truck on jack stands vs. a lift.
Your tire size would depend on your wheel size and backspacing. I wouldn't be able to fit a bigger tire on mine, it barely clears now.
looks mean
