Add-a-Leafs?
Old Mar 15, 2006 | 12:09 AM
-TXF150-'s Avatar
Originally Posted by ThumperMX113
Could you also find the price on the 3" leaf spring kit? I could use the 3" kit plus the factory 2" block, correct?
Yes, you can, I'll get prices on both of them...
Old Mar 15, 2006 | 11:46 AM
-TXF150-'s Avatar
Thumper, You can see the leaf packs in this picture:
I found the 4'' pair for $275 shipped. The 3" is only an add-a-leaf, I say you should get the 4" kit, and you will be good to go..
Old Mar 15, 2006 | 01:42 PM
CRFracer's Avatar
Don't you need some kind of block in order to get your rear end angled just right? I know the stock blocks on my old F250 were wedge shaped and if I'd have set the leaf springs right on the axle housing it would have increased the angle of the drive shaft/differential connection.
Old Mar 15, 2006 | 03:20 PM
REDTXFX4's Avatar
There is a Fabtech 5" block listed on eBay (listed as 4"), you might want to check it out. I have mine sitting on my desk ready to be installed with my autospring. I can't wait hopefully next weekend!
Old Mar 15, 2006 | 03:23 PM
ThumperMX113's Avatar
Do you think the ride on and offroad will be improved?
Thanks -TX150-
Theres a reason why I want to go to a smaller block. .
Old Mar 15, 2006 | 08:37 PM
-TXF150-'s Avatar
Thanks -TX150-
I think the ride will definitely be improved.. If I would have know that the pair of leaf packs was only 275, I would have added them a long time ago. I will be adding them, along with fox reservoir shocks towards the middle of the year..
Old Mar 15, 2006 | 08:56 PM
scottiebe's Avatar
hey thumper, stay away from blocks! back in the day of my off roading, blocks burned me! I would just go to your local spring shop, they will hook you right up, at least here they do. I blew out a block one day on my way to a wheelin' party, I went in to the spring shop, they built me 2 new leaf packs right there, and installed them. My wallet was $100.00 lighter and I was back on the road in about 1.5 - 2 hrs. After that, I swore Id never use blocks agin!
Old Mar 15, 2006 | 09:17 PM
-TX150-
Are you just going to use the 4" leaf pack? I know Im currently using a 4-1/2" block and it sits level but when I just had the 4" block, I was sitting bulldog. . Are you worried about sitting bulldog?
Old Mar 17, 2006 | 04:41 PM
REDTXFX4's Avatar
Hey I'm curious where you found those leaf packs at that price TXF150. All the places I looked it was like $350+ for one Of course my luck this thread comes up after I got my bigger blocks. Maybe I could return them haha
Old Mar 17, 2006 | 04:49 PM
Silver05's Avatar
I might consider running this system. I'm running a 5 inch block in the back as we speak. I sit a tad bit higher in the front. I'm hopin it settles down just a bit.
