Need Help with KC Lights
OK, I got my KC Lights yesterday and looking at the mounting system Im not sure how they go on to the Westin Bull Bar. BTW these are the "Shock Mounted" Lights. If anyone could provide some help or pictures Id really appreciate it. TIA.
On the top of the bar there are 2 holes that are plauged. Pull out the plugs. On the bottom of the bar there are 2 holes where you can put the nut on. It is very hard to do with the bar on the truck. I put mine on before i put the bar on. It was way easier. You need to use a socket and an extension through one of the openings of the skid plate to put the nut on. It's not easy but it can be done.
I got the part about the holes and all but where does the rubber washers and metal covers go? do they go one on each side or all on the bottom or what? If someone could post a close up of their install maybe it would help.
I ordered em from truckperformance.com they had the option of shock mounted or not so i got the shock mounted ones there basically just little rubber bumpers I guess. http://www.kchilites.com/store/repl_daylighter.aspx
Looking at the rest of the lights they look the same except mine came with two additional pieces of rubber with aluminum covers which I dont think there gonna work in this application without looking goofy.
