LED Replacement Signal Bulbs - HELP
Old Mar 8, 2006 | 12:45 PM
Robamus's Avatar
Hey everyone, I did search and didnt find much... But I bought new brake lights, front corner signals, and the lights in the 3rd brake light all are LED. I installed the brake light/turn signals in the rear and they flash way too fast. So, after a bit of research, I learn that there is not enough resistance, and the truck basically thinks the buls is burned out. I found that you can get either a resistance simulator, and install one at each spot there is a LED light (At $5/ea.), or a turn signal relay flasher thingie that will work with the LED lights, but it doesnt look like it works with these new trucks after taking a look at mine.
I have a couple questions; has anyone done this? If so, what did you use and if you have it, whats the part number? Is there another way I am not aware of?
Thanks in advance, and just so you guys know I got these lights off eBay for a total of $37 shipped. Ill be happy to share the sellers name if anyone is interested.
Old Mar 8, 2006 | 02:12 PM
HCFR-Halligan's Avatar
I believe I read somewhere that you could just install radio shack resistors in line with them. If so that would probly be the cheapest route.
Old Mar 8, 2006 | 02:36 PM
GotBeer's Avatar
I had the same problem with my streetbike when I switched to LED's. All I did was remove the factory flasher relay and wire in an EL-12 relay available at any autoparts store. Its only 2 wires. Have to look in your manual to see where the flasher relay is. The part is like 5 bucks.
Old Mar 8, 2006 | 11:02 PM
Matt 05'FX4's Avatar
I wired one of these at each front signal. It is 3 Ohms and simulates 2 bulbs so only one per side is necessary. They get really hot if you leave your signals on for too long, so they need to be away from anything that can melt!
LINK!!!!!!!!!!
Old Mar 9, 2006 | 01:30 AM
bluestang67's Avatar
matt thanks you know it's very hard to find good help like you . Seen some of your posts and belive me . Thank You
Old Mar 9, 2006 | 02:14 AM
Robamus's Avatar
Thanks Matt!!!!! I just placed my order and will update this when my parts come... No doubt someone will be doing this and will have the same question...
Old Mar 9, 2006 | 07:41 PM
No problem fellas, I love helping fellow onefiddy owners out because they have and I hope they continue to do the same to me!
