Edge update 03/01/2006
Edge apparently updated yesterday. Here is what their pdf says:
Evolution Lightning Software:
• v1.02.0114 (03/01/2006)
o Added the Custom Option Editor module which allows simplified adjustment of tuning parameters. User is now able to load, store and edit custom tuning options is a more easily visible format. This module requires a full install of the Lightning software.
o Added additional version check to correctly identify currently programmed level.
Evolution Firmware:
• v14 (03/01/2006)
o Fixed [Display] -> [Setup] menu when changing AMPG or IMPG display selections.
o Fixed problem with Timing Adjust where value was stored incorrectly in EEPROM.
o Fixed data type conversion problem which could cause values to be stored or applied incorrectly.
o Fixed issues where "Reset MPG" would come up when unit was restarted due to the [Enter] key being held down. We now wait for the key to be released before proceeding.
Evolution Calibration:
• v16a (03/01/2006)
o Address P1205 / P1233 DTC on 4.6L vehicles
o Fixed custom option issue on some 2004 trucks where engine idle would be unusually high (about 1600 RPM) after changing "Idle Speed" under the custom options.
Evolution Firmware:
• v14 (03/01/2006)
• v16a (03/01/2006)
