Edge "?"
Old Feb 27, 2006 | 08:51 AM
Silverfish's Avatar
Edge "?"
I bought the Edge for my 2005 with the 5.4....this tuner is awesome. I loaded level 2 and it now feels like a V-8. The gas pedal is responsive from all pedal positions. I ran a 7.1 sec 0-60 (x-cab, 3:73 gears ls, stock). I will try level 3 in a couple days....
My question: Can I load this on my friends 2004 f150 truck with 4.6 so he can feel the difference? Not sure with the different engine. (I know that I need to restore my truck before loading onto his). Thanks for your input.
Old Feb 27, 2006 | 09:22 AM
05supercrew's Avatar
Im seriously thinking of the Edge being my next mod now.
Old Feb 27, 2006 | 09:32 AM
MosineeFX4's Avatar
I believe you should be able to. I would make sure that you have the latest update though, I think the version that came loaded on the tuner didn't initially support some of the 4.6l codes.
Old Feb 27, 2006 | 11:04 AM
FX4_Guy's Avatar
Yes you can. Make sure that you set your truck back to stock before you disconnect the edge. Then you can install it on his truck.
The Edge can only work on one truck at a time. If you change trucks without changing the unit back to stock before you switch....you run the risk of creating a 6000# boat anchor. I can't stress enough.......Put the vehicle back to stock before you switch vehicles.
Old Feb 27, 2006 | 01:22 PM
Y2KWHT150's Avatar
Do you guys hear louder air intake or exhaust rumble noise or is it just me!!! I swear I think it is louder....I just I can set it back to stock to test it myself but would like to get some feedback from others as well
Old Feb 27, 2006 | 01:39 PM
Kool Aid's Avatar
I'm not sure if I would call it louder.....but it does sound different.
Old Feb 27, 2006 | 05:51 PM
ThumperMX113's Avatar
My exhaust seems louder.
Old Feb 27, 2006 | 06:13 PM
bushtree's Avatar
my engine seems to Whine a lot more at higher rpms...
Old Feb 27, 2006 | 07:15 PM
Y2KWHT150's Avatar
So...it's not just me than...the we are hearing little louder at the both end
