Will this work
Will this work
Thinking about getting a rancho 4" lift and adding my 2" autospring spacer to it.
Question is do you think I can run 36/14.50/20 dirt grips without any probs? I would also like them sticking out around 3 or 4 inches , will this cause a fittament problem too?
I think you will have no problem. Thumper on here has this setup except with 35s. Ask him about it. BTW 3-4 inches is A LOT!! i have 4.5" backspacing on my wheels and they stick out 1-2 inches and some people say that is a lot.
I have heard that the Rancho lift is more than 4". I have heard it is like 5 or even 6. And i have seen people with 36" tires some with even 37 on just a 6" lift and you are putting a spacer so I think you will be fine. The only thing is that the front might be a little higher than the back since you are putting on a spacer. I would put a bigger block in the back or a add-a-leaf to make it level.
