High Pitched Whistle Coming from Engine in Cold Weather?
Old Mar 1, 2009 | 11:36 AM
  #196
CometFlash's Avatar
Angry
Easy fix for the the early morning cold whine that goes away and really is no trouble or concern at all, and for my absolutely awful constant engine howl - trade it in for a 2009 like I'm doing. Problem solved.
Only have to listen to that horrid engine whine for another 6 weeks or so, hopefully it will arrive in early April.
Still not sure why the very short-lived whistle on cold morning start-up's that goes away fairly quickly is bothering anyone, seems extremely minor to me. Try living with a high-pitched engine howl that NEVER goes away as long as you are giving the vehicle gas, no matter speed. Total nightmare. Can't wait to say goodbye to this 2004!!!
Old Aug 14, 2009 | 12:57 AM
  #197
Fire Chicken's Avatar
I had the high pitch whistle noise. Only occurred at cold temperatures and the whistle pitch worsened with speed/rpms. After Ford replaced belts and tensioner, the alternator was replaced. That fixed the problem. Was told by one dealer that this is common.
Old Sep 21, 2009 | 10:37 PM
  #198
Big Red P225's Avatar
The whistle happens in cold air only while the air intake is still cold. You should notice this only under light throttle and only until the air intake warms up. The reason is the air rushing through the intake and whistling across either the intake or one of the hemholtz resinators. The cold intake is slightly smaller and the dense air together cause this. As soon as the intake warms it expands the opening slightly and the air rushing across no longer set up the standing wave. Mine almost sounds like a a tug-boat whistle. This is similar to the sound from blowing across a glass soda bottle (or beer bottle). The production air intake has either 3 or 4 hemholtz resinators on it already, so there isn't any room for another which really is only needed for 2 minutes during sub-zero temps.
There is nothing wrong with the truck and there would be no fixes from a dealer. Of course you will never be able to repeat this at a dealer because it will warm up enough by the time you get there that it cannot make the noise.
Old Dec 3, 2009 | 12:51 PM
  #199
turtle313's Avatar
Smokewagun update?
Originally Posted by Smokewagun
Can I quote myself? I reinstalled my tunes and the AF-1. Guess what? The whistle/squeak is back. It is definitely intake/throttle related. I am thinking about getting am O-ring to put around the MAS to seal it better and then seeing if it helps. I may try the old brake cleaner deal by spraying it around the intake fittings and throttle body to see if a change in engine RPM (surge) indicates a leak somewhere. I was accepting the alternator thing until the stock intake eliminated the noise. I'm sure the AF-1 is just magnifying the noise... why would the AF-1 start this noise after thousands of miles? I'll tell 'ya, sometimes it's so loud, the guy in the car next to me gives me weird looks. I hate that. I think I'm driving a weenie whistle!
Mine is doing almost the exact same thing and I'm running the same tune and intakes as you. Did you ever get this fixed?
Old Dec 4, 2009 | 08:46 PM
  #200
Thunden's Avatar
Ladies and Gentleman, pls forgive me as I did not read every post. I am new to the forum and I have an 05 f-150, 5.4l. I to have the dreaded whistle. To me it reminds me of the sound effect when the coyote falls off a cliff (which is what I would like to do to my truck right now). I have noticed that it really only makes this whistle at certian mph ranges such as 62-64ish mph and 72-75ish mph. When I let off the gas and coast it becomes louder until I coast under the mentioned mph. To me it really sounds like it is coming from the speedometer. Do we have mechanical or elect speedometers?
Old Dec 4, 2009 | 09:00 PM
  #201
Paralyzer's Avatar
ive been fighting with this noise on my parents truck for the past few winters. This year I changed the belt and noise is gone.
Old Dec 5, 2009 | 03:15 PM
  #202
turtle313's Avatar
Mine is not a belt and has nothing to do with speed. It is for sure coming from the intake.
Old Dec 10, 2009 | 05:11 PM
  #203
plmn's Avatar
Is there a specific brand belt you used?
This whistle is driving me nuts, really loud when the temps below 0.
Old Dec 12, 2009 | 10:30 PM
  #204
copbait's Avatar
has anybody tried replacing the fan clutch yet, I swear that is what I am hearing. I am glad I am not the only person fighting this darn issue
Old Dec 13, 2009 | 02:27 PM
  #205
Paralyzer's Avatar
replaced with another motrcraft belt, high pitch whistle/hooting is gone.
Old Dec 18, 2009 | 04:39 PM
  #206
Sopher's Avatar
I guess it could be the intake. But on my NEW 2009 F150 with just 6300 miles, the whistle occurs above 45mph on cold days and stays pretty constant. It only lessens when I open the driver window presumably that changes the path and cabin pressure.
I do love my heated seats in the winter!
Old Jan 8, 2010 | 09:23 PM
  #207
copbait's Avatar
I got it
Originally Posted by 2stroked
I think if you read back through this thread you're going to find that there's a number of different "whistles" folks are talking about. I believe there's at least two main types here: 1) A noise when the vehicle is cold - regardless of engine RPM - and it goes away when the vehicle warms up, and 2) a noise only right around 1,800 RPM when it's cold - that never goes away unless you change the engine speed. Warming the vehicle up has absolutley no effect on this one.
Here's the important part. The TSB just posted up does not deal with the second condition. I'd seen this TSB a while ago and actually purchased the part - along with a new alternator. (I had condition #2.) We put the alternator in first and it solved the whole problem. I took the other part back. So, before you run out and do something silly ...
Thanks to 2stroked you were right all along, I did not think it could ever be my alternator but it was. After a fan clutch did not fix it I decided to try the alternator and that did it. Thanks
Old Jan 8, 2010 | 09:43 PM
  #208
One Shot Luni's Avatar
The alternator.
Old Jan 9, 2010 | 11:12 AM
  #209
07BlueLariat's Avatar
when you get old enough you wont be able to hear it lol :] but for now my truck always whistles and doesn't bother me at all
Old Jan 9, 2010 | 11:25 AM
  #210
davidmaupin's Avatar
high pitch whine
I have a 05 fx4 with 5.4. I bought it used, i now have a high pitch whine at 60 to 70 mph. It did start until i checked the air filter. It is cold outside. any help on fixing it.
