Transmission Oil need advise
Old Feb 8, 2006 | 10:04 PM
artgarcia's Avatar
I need to change the transmission oil, my FX4 needs Mercon V. What brand is better to use? I do a search with no results.
Thanks in Advance!
Old Feb 8, 2006 | 10:16 PM
Quintin's Avatar
I used Motorcraft brand Mercon V (part # XT-5-QM). Although I suppose any reputable brand that meets Mercon V specs will do.
Old Feb 8, 2006 | 10:44 PM
ALLAXCS's Avatar
You could run some Moble 1 synthetic. It's pricey. It will run a little cooler, which is good.
Old Feb 9, 2006 | 01:53 AM
KSpencer's Avatar
Like what, 2 degrees? Just use what is recommended. I have used Motorcraft cherry juice and motor oil in all of my vehicles for 14 years with not one failure from either.
Old Feb 9, 2006 | 10:25 AM
artgarcia's Avatar
Thanks for the info, Where is the cheapest place to buy the Motorcraft Mercon V oil?
Old Feb 9, 2006 | 02:02 PM
04NickySP2's Avatar
I've noticed the bigger Wal-Marts seem to carry Motorcraft products.
Old Feb 9, 2006 | 02:18 PM
country_duck's Avatar
If that is your concern then you might as well add a beefy tranny FLUID cooler (other than the stock things)
Old Feb 9, 2006 | 02:27 PM
kd4crs's Avatar
I would stick to what Uncle Henry Ford speceifies. That way your warranty status should be preserved.
