Body Lift Questions, Pics Please
Old Jan 30, 2006 | 08:55 PM
eaglelumbee's Avatar
I am think about getting a body lift for my truck. I was wondering what you have to do to the front of the truck when lifting it becuase the details online say you have to do some modifications to the front.
Also for ones that have the body lift do you feel like the truck is as structurly sound as it was from the factory. I lifted my 99 Ranger and 87 F150 with a body lift and I loved it.
Also do you think that it will void any warrenty?
If you have detail pics please let me know.
Thanks!!!
Old Jan 30, 2006 | 09:45 PM
RAYJAY25's Avatar
Read This
http://www.performancelifts.com/inst...ries/70063.pdf
Check this out all you need to know
Hope this helps
Old Jan 31, 2006 | 08:12 AM
wandell's Avatar
I can't speak on your truck, but I have owned 3 trucks with a body lift. I've never had a problem with any of them. The biggest advantages of a body lift are cost, the ride is not affected and you warranty is not voided. As for the front end, I had to due some custom fabrication to mount some towhooks, but that was it.
Old Jan 31, 2006 | 08:15 AM
ThumperMX113's Avatar
BTT!
I'd like to see some pictures of the rear hitch after the body.
Old Jan 31, 2006 | 08:27 AM
wandell's Avatar
Here's what an 01 looks like.
Old Jan 31, 2006 | 08:28 AM
Wandell, remember that big DSG that was running a 6" and a 3" body?
Well he said he had fabricated something to make the hitch appear stock, do you have any idea what he did?
Old Jan 31, 2006 | 01:58 PM
wandell's Avatar
He probably cut the mounting brackets and rewelded them.
Old Jan 31, 2006 | 05:31 PM
Thanks for all your help!! I think that I am going to get a body lift.
Old Jan 31, 2006 | 05:33 PM
JJG052590's Avatar
Banned
Body lfits=way to go & not expensive!!!
Old Feb 20, 2006 | 05:24 PM
speeddemon13's Avatar
If I get a 3" body lift on my 01 F150, what is the biggest tires I can put on? I think 315/70R17 right? How much should it cost to get a body lift installed?
Old Feb 20, 2006 | 05:29 PM
KiCk aSs FX4's Avatar
body lifts look funny. the trailer hitch will be low, you will see too much in the wheel wells and under the truck, and the front tow hooks will be under the front valence.
Old Feb 20, 2006 | 05:34 PM
If I get one I will buy the gap guards to cover up the gab, I dont have a hitch so that wont stick out and I dont know if I have the front tow hooks.
Old Feb 20, 2006 | 10:29 PM
First off, you can modify the hitch brackets to make it look just like stock, you won't see too much in the wheel-well unless you don't get bigger tires, if you have step bars it'll cover up the frame. Finally, about the tow hooks if you HAVE to keep them, you could always just dremel out the bottom of the opening. However, in my case Im just going to make custom brackets to move my bull bar up so you won't ever know. Body lifts arn't really bad.
Im sure you'll change your mind once you get bored with 35s and want more. .
If you have 4wd, than yes you have tow hooks. If you have a 2wd, more than likely you don't
