Power windows stopped working, couple of Questions
My power windows stopped working last night. The Driver can controle them but the passangers cant controle them. This happen to anyone else or just me. It's the first problem I've had with it so I dont know what to think. I'm gonna take it to the dealer monday and get it fixed. Could it be a fuse or do you think they just messed up?
First thing to do is check that the lockout button for the windows is not on. As you are looking at the controls on the drivers side arm rest it is the last switch toward the back of the truck. Check it's position and the try the windows again.
I sure hope that's the first thing he checked.
Try this first, this is a test of that switch for the passenger/rear window lockout. Go out when it is dark and turn the key on and lights on. Look at the passenger/rear switches, are the green arrows lit up? I know that when you have the switch unlocked for P/R windows, the lights will come on, and when it is in lockout mode, the lights go off. This is just the window switch, not the unlock/lock switch. If the lights aren't comming on then most likely either something is wrong with the driver's switch group or there is a fuse blown.
