edge error message for me now....
Old Jan 25, 2006 | 06:43 PM
jims94vmx's Avatar
just did two tanks on the tow tune and had it customized, now tonight filled up with 93 octane to play with level 3 and when asked if i wanted a custom tune i said yes, then started with the wot prompts and got the 01fx error code.....went back and just loaded the edge #3 tune and that took.....i did get the latest reflash about 2 mos ago....maybe that has something to do with it....weird how i could customize level 2 though.....
Old Jan 25, 2006 | 06:46 PM
expy03's Avatar
Same thing happened to me when I loaded the #3. I had to turn on the key, unplug the unit, plug it back in with the key still on, and start over. I think it is in the manual that you may have to do it. I just went back to the #2, and had no problems.
Old Jan 25, 2006 | 07:28 PM
kmk's Avatar
kmk
On page 36 of Edge manual it covers the error code. I think this will take of your problem.
Old Jan 25, 2006 | 09:28 PM
expy03's Avatar
This is from page 36.
• ERROR CODE 0xF1 (AFTER PCM READ) – If you are receiving this error
code right after the Evolution reads your PCM, check for updates using the
Lightning® software. If the problem continues, go to the Utilities menu and select
Read Stock Calibration. Then call tech support to take steps to create a new
calibration for your vehicle.
• ERROR CODE 0xF1 (IN CUSTOM MENU) – If you are receiving this error
code while trying to configure your custom options, disconnect from the OBDII
connector, turn the key to the ON position, and plug the Evolution back in. After
getting to the main screen (past Intro and Disclaimer), wait 15 seconds. This will
give your unit time to load parameters it needs to perform the custom changes.
Old Jan 25, 2006 | 09:38 PM
jims94vmx's Avatar
thanks guys. will do that tomorrow morning......appreciate it....
Old Jan 26, 2006 | 02:44 AM
Kool Aid's Avatar
Is it easier to read the instructions someone posts here or in the book you have at home?
Old Jan 26, 2006 | 11:22 AM
jims94vmx's Avatar
absolutely easier......! besides it is cold outside and my instruction book is in the truck.....and i like the company of this list
Old Jan 26, 2006 | 11:34 AM
expy03's Avatar
Aw give the guy a break. You live in Tampa, and I live in Arizona. We don't know what cold is. Besides, I have it on PDF, so I don't have to go out to the truck.
Old Jan 26, 2006 | 01:07 PM
jims94vmx's Avatar
thanks for feeling my pain!! now if i could only feel my fingers
just came back from doing the unplug, key on, plug in test, it loaded my custom program in level 3! will go out and play later...eventually want to compare the level 2 perfomance runs with level 3 to see how it does......want to let it adapt and learn for awhile first and also warm up out of the low 30's that it is today! see ya board..........
Old Jan 26, 2006 | 01:30 PM
expy03's Avatar
Glad it worked out for you. I was running #3, and just loaded #1 after the update. I'm taking a trip this weekend and want to see if it makes any difference in fuel mileage.
