How To Remove F150 Badges
The best way to get them off is to use a piece of hard plastic (credit card, maybe) to slide under the badge and get it started. Once you get an edge loose, you should be able to pull them off by hand.
Btw, I'm not sure your reasoning for taking the badges off, but if you want to remove them permanantly, just remember that there are large holes under the badge to aid with locating them. I really want to remove mine, but that would mean that I would have to weld the holes shut and refinish the fenders. Just a little more work than I want to get into right now.
I got two words for ya... DENTAL FLOSS
Also, use a heat gun and some "goof off" to remove the excess adhesive.
Trust me... I had to remove SEVEN badges on each side of my wife's titan... Each letter is a badge (V-8 T-I-T-A-N).
took me 2 hours...
took me 2 hours...
