Inspection not so good with edge!
Alright well i installed the 2.5leveling kit the other night and took it in to get re-aligned and inspected since its time. I have the edge programmer as you know.Well i decided to put it back to stock and took it down. They worked on it all day re-aligning, cutting rotors but it wouldnt pass emissions. So i turned it back to level 2 towing like they wanted. It ended up passing 8 out of 10 emissions. They say i need to drive it more so the codes will be reporgrammed!! What is going on here??
I tuned it to stock the night before i dropped it off.When they hooked their computer up to it...no codes showed up?? So they suggested putting it back to the tune i've had on. They drove it around for awhile and i guess more codes worked! I dunno. Something doesnt seem right.
How long is the drive cyle? I've driven it around after tuned up
Any info would be great
It probably had a P1000 code showing. A P1000 means that the vehicle has not completed a "drive cycle" readiness test since the last time power was interrupted to the PCM. This code will show when either the PCM is reflashed or the battery is disconnected. What the emissions computer is doing is checking for service codes and if it shows this one it probably thinks the codes were cleared in order to pass the emissions test. I am not sure what is considered a drive cycle but I think its a "cold to operating temp" drive??? Maybe it takes more than one drive cycle to get rid of the p1000 code???
http://www.obdii.com/drivecycleford.html
Cheers
Grog
Originally Posted by 04NickySP2
Another reason you shouldn't purchase the Edge
MGD that was a good link but they forgot the drive down to the pub step.
At least in my state.. Connecticut..
Jack
