What inch Autospring with this setup?
Old Jan 19, 2006 | 05:44 PM
Originally Posted by 04NickySP2
Actually I don't really like the tail/headlights. And that isn't me in the picture.
OK, I won't try to stick up for anyone anymore. Good intentions gone to waste.
Old Jan 20, 2006 | 05:11 PM
Jason Jones's Avatar
WOW this Thread is a little off topic...
Thanks 04NickySP2 for the pic of your truck, and no your truck does not look noes high. You do have the Autospring kit right?
Aaron_j Thanks for your input, I think I'll being going with the 2.5 kit with 35" BFG.
Old Feb 8, 2006 | 01:19 AM
Beefullo's Avatar
Originally Posted by BalogUK
you'll be fine with the 2.5- no bulldogging (nose high) if you tow heavy heavy loads, you may want to invest in something else, or you will notice some high end. 35's should be fine if you keep your stock rims, if you go aftermarket, youmay experience some minor rubbing depending on your rim backspacing, etc.
ive got 33's on stock 18s,a nd a 2.5" autospring. pics in the sig.
Rim backspacing, hmm...Isn't there a way to change this by adding something? If not what is the correct backspacing and what wheels generally come with such.
Old Feb 8, 2006 | 01:40 AM
BalogUK's Avatar
you probably want to stay away from any 'add-on' parts to the hubs up front... if i remember correctly-and if im wrong, im sure i'll be corrected- the backspacing is 5.5" you want to stay as close as possible to that number. the stock rims are 17/8 x 7.5 if you are running 35+ you need a wider rim - 8.5" or wider. but then you need to recheck your backspacing, because you just added an inch minimum in overall width...
Old Feb 8, 2006 | 08:49 AM
kdds05screw's Avatar
Glad we are back on the subject here:
My experience, I recently added the 2" AS on my 06FX4 scab and wound up with 2 1/2" of lift - even after alignment. Now the front and rear are exactly equal. Looking at add-a-leafs now just to get the rear 1" up... Point here is you may get more than 2" on the "2 inch" leveler.
Old Feb 8, 2006 | 08:58 AM
giorgioF150's Avatar
Originally Posted by ThumperMX113
35s will fit if you keep your rims however, aftermarket you'll rub for sure, and Im pretty sure it won't be minor. I had rubbing with 33s and 2-1/2" Daystar and 33x13x18 Nitto Terra Grapplers. .
Hi
What does "aftermarket" means?
Thank you
Giorgio
