remote start wiring
remote start wiring
okay guys here is the deal I have the accele as36 alarm and I want to setup a setup remote start I was lookin through the paperwork trying to figure out how to do something else and I saw that I could do it. I can upload the wiring diagram later when I get off work. Also while I am on the alarm issue if someone can figure out how to setup a lock switch.
I'm not sure what your exact question is?
I never heard of an "accele" alarm/starter. well, there's this webpage that gives instructions for installing the Ford/Code Alarm remote starters and alarms, it should help you some: http://www.gemsen.com/ford/
first thanks for the response, what happen i bought an alarm, bottom of the line. I just wanted it to go off I didn't need it to do anything special. So it works okay but as I was reading the instructions it says that it supports remote starting. So the way I see it I might as well just wire it up if I can. Also when I got the alarm installed they did not put a switch to lock or unlock the doors so I would like to add those aswell.
