Tailgate Will Not Lock
Hey Guys I got a 04 F150 S.Crew and the Tailgate will not lock. I tried both sets of ignition keys and it will not lock, it's like it's the wrong key because when i put the key in the hole I can not even turn the key. Any Ideas or anyone else had this problem? I think the lock might just need adjusted? What to ya think? Thanks for the help
You can get to the cylinder fairly easy by taking off the 8 bolts on the back of the tailgate and remove the panel, the cylinder is just held in by a locking ring, slide it out remove the cylinder and clean it out.
It's possible the tailgate was swapped due to shipment damage, and they forgot to swap the lock cylinders. I had the tailgate swapped on my truck due to deep scratches under the dealer sticker. The dealer initially forgot to swap the lock cylinder with it.
