Interior Paint for Edge Pod?
Old Jan 5, 2006 | 08:18 PM
  #31
one eyed willy's Avatar
i have a 05 with tan interior and dark brown trim,any body have a code for it maybe as well?
i just got my edge today and want to paint the peice before i put it in.
Old Jan 5, 2006 | 08:20 PM
  #32
ThumperMX113's Avatar
Find out what your interior code is and than look at that paint chart.
Old Jan 5, 2006 | 08:31 PM
  #33
F150Truck'in's Avatar
Thumper's on top of the interior code paint deal now
Glad I could help you Thumper, I'm just not 100% sure on yours....
guys,
remember the Interior Code is two digits or letters or both, but only the second digit in the code is paint... the first one is the trim package on the interior......
Old Jan 5, 2006 | 08:48 PM
  #34
Thanks a ton again F150Truck'in
Old Jan 8, 2006 | 06:27 PM
  #35
Tical84's Avatar
I just want to make sure I'm understanding this right...
My interior code was ME so using E on that pdf chart for F-Series it came up with Black, Med. Flint and Dark Flint. That means the colour I want is going to be one of those three?
I only see two colours in mine. One is a light grey and the other is darker but not quite black. Shall I assume that the lightest part is Med. Flint and the darest part Dark Flint?
This is the best pic I have at the moment. I think it's the same as F150Truck'in but if I'm reading this chart right and am correct on assuming that it's Dark Flint, then my code should be M4JZ-19M547-2002H.
Old Jan 8, 2006 | 06:59 PM
  #36
Correct Tical,
You do have some black, around radio, around door handles, and some in few more spots...
Mine is PE so "E" mind and yours should be the same color...
I ordered Dark Flint, M4JZ-19M547-2002H
have not gotten it yet, just ordered from local dealer and was told about 2 weeks for it to come in....
BTW, thanks for setting up that group buy, my truck is a lot better now and is running 7.40's at 60mph...
Old Jan 8, 2006 | 07:16 PM
  #37
Tical84's Avatar
Thanks, just wanted to make sure I was reading that right.
I'm still waiting on mine
The last entry with the tracking number I have said it entered Canada on the 5th and non-stop drive I'm only about 4 hours from where it entered so hopefully I'll get it tomorrow or Tuesday.
I've already read the manual twice and I've read everyone's opinions on it so I thought I'd get the paint code while I continue to wait.
Old Jan 8, 2006 | 09:44 PM
  #38
Newt's Avatar
Hey Gordon
Hard to believe you're the last of the group to get theirs
I'll probably eventually paint my pod. But, the black doesn't look bad in the Lariat.
I haven't even used the double sided tape or valcro that comes with it. It just sits there & doesn't move. A no trace removal if that becomes necessary.
Old Jan 14, 2006 | 11:56 AM
  #39
nvrenuff's Avatar
OK, I must be a little slow, but my int paint code is "JB". Its a 2004 FX4 with black interior with a similar grey color as Tical's for the trim. But when you look up B in the 2004 interior chart, it only lists one color, charcoal black, so do I just guess the grey color is the same as Tical's
Old Jan 14, 2006 | 12:47 PM
  #40
QUOTE=nvrenuff]OK, I must be a little slow, but my int paint code is "JB". Its a 2004 FX4 with black interior with a similar grey color as Tical's for the trim. But when you look up B in the 2004 interior chart, it only lists one color, charcoal black, so do I just guess the grey color is the same as Tical's [/QUOTE]
It does only show one color, shoot a couple pics of you interior and i'll try to help you,
BTW look in my gallery, mine and Tical's dashes are the same code
Tical "ME"
F150Truck'in "PE"
Old Jan 14, 2006 | 01:02 PM
  #41
nvrenuff's Avatar
interior-black fx4
This is a pic of the whole interior I found on a ford site which looks like mine. Anyone know if they have changed the FX4 interior from 04 to 06.
*edit- form the link, just hit photo gallery and then interior
Below is partial shot of my interior.
my interior
Old Jan 14, 2006 | 01:29 PM
  #42
Originally Posted by nvrenuff
interior-black fx4
my interior
looks like you may have the same sliver looking color that ThumperMX113 is looking for that we can't find a listing on... so check with him to see if he tracked it down yet !!
Sorry, this is one color i'm not sure about....
Old Jan 14, 2006 | 07:10 PM
  #43
shookman34's Avatar
Thanks for going through all the trouble to find the paint codes...I'll probably order it as well. I haven't mounted the pod yet because I was a little leary of the tiny strips of tape that came with it. Right now my Edge is sitting in the cupholder/ashtray with the cable routed under the dash, but since I don't like it sitting loose there I'll probably end up just mounting the pod and hope it doesn't come loose....maybe go out and buy some beefier tape.
Old Jan 14, 2006 | 09:52 PM
  #44
jpetre's Avatar
Man I can't believe we can't figure this out. I would think that 50 out of the 64 would be looking for this color. Anybody have any ideas yet?
Old Jan 14, 2006 | 10:33 PM
  #45
Tical84's Avatar
I don't get it either. Either that pdf is incomplete or all of you are looking at the wrong code. I'm thinking the first one. For "B" it only has two choices and both are for the Thunderbird, there are no options for the F-Series.
It does look alot like my dash but reversed. I wonder if it's the med. flint.
As for One Eyed *****'s I don't know if that would be the pebble or parchment.
