Poll: Which Wheels + Tires *PICS*
okay this is the last time i will make one of these forums. I will probably be getting my lift in early January (the 13th). Just trying to make some last decisions. I am considering the moto metal 951s or the Rubicon Offroad Volt 6 both in 18s. The Tires I am considering are Cooper Discovery STTs or Mickey Thompson Baja Claw Radials or the Toyo Open Country MTs (if they are available in time). The cooper and toyo tires I am looking at 35/12.50/18. The Mickey Thopson Baja Claw Radials I am looking at either the 325/65R18 (34.6", 12.8" width) or the 375/60R18 (35.7", 14.8" width).<<<is 14.8" width too big?? I am going to use a 9" wheel. Anyway here are a few pics. Which do you like??
TIRES:
1.
2.
3.
Toyo Open Country M/Ts
TIRES:
1.
2.
3.
Get the Moto Metals in black! I would go with the Baja Claws. You might consider the Pro Comp X-Terrains as well (similar tread, and 4WheelParts does the buy 3 tires, get the 4th free quite often.)
Black moto's and the Coopers. I have had great wear from any Cooper tire I have ever used. They also stand behind thier products with warranty issues if needed. I was helped with a "warranty" issue even though it was more my fault than the tire failing. (I never should have tried to go there...you know the drill)
BJ
BJ
As soon as I am actually HOME during DAYLIGHT
, I'll post some pics of the Moto Metals with Nitto Mud Grapplers...
All it took were two pictures for me to change my mind from M/T tires to Nittos. Obviously, I'm implying that once you see my combo, you'll probably change your mind on the tires.
So, I vote for #X (Nittos) and 4.
, I'll post some pics of the Moto Metals with Nitto Mud Grapplers...All it took were two pictures for me to change my mind from M/T tires to Nittos. Obviously, I'm implying that once you see my combo, you'll probably change your mind on the tires.
