Lariat owners - MPG readout
Old Dec 23, 2005 | 03:13 AM
Grubrunner's Avatar
Question Lariat owners - MPG readout
I've just topped 3K on my 2005 Screw Lariat 4X4 purchased this past September .
I reset the MPG readout when I got it home with 13miles on the clock.
Ever since, it has NOT reached over 12.6MPG . . . . regardless of my driving habits.
Over 80% of my driving is highway. I have a 25mile commute to work and I take the truck in every now 'n then and will do some weekend driving when I'm in the mood to get my fat *** up in the drivers seat (this thing's jacked up compared to my '03 Sonoma I drive every day). It's a secondary vehicle, in other words.
Does 12.6 MPG with just over 3K on the clock, and predominantly highway driving, sound about right? I'm thinking I should be getting figures that are something a LOT more economical than this. Correct? Should I take the truck into Ford and tell 'em something's up? A reflash perhaps? Power is no problem. It drives like a dream and I rarely, if ever, give it WOT. Only engine mod, thus far, is a K&N airfilter in the factory location . . . everything else is bone stock.
What's up with that? Or am I expecting too much?
I dunno so I'm asking the board for its assistance . . . . any advice/assistance would be greatly appreciated.
PS: What MPG figures are the rest of you getting? Under what driving conditions?
Old Dec 23, 2005 | 03:24 AM
Screw2004's Avatar
That sounds about right.The next time you get on the freeway hit the reset button again and should go up
Old Dec 23, 2005 | 07:01 AM
afphinfan's Avatar
Mine read 12.8 mpg when I put the Access rollup bed cover and K&N air filter in. Now it reads 14.5 ... still not stellar but something is better than nothing being that I needed those accessories anyway.
Old Dec 23, 2005 | 08:21 AM
Crstfr's Avatar
man i just did mine this morning... this tank was 12.8... arrgg.. i have the 35gal too!.... maybe a new muffler would help.. stock smock
chris
Old Dec 23, 2005 | 08:35 AM
GrizfromKY's Avatar
I avg around 15.5. But I have a 2wd.
Old Dec 23, 2005 | 10:10 AM
billindenver's Avatar
Well hanging a brush guard out in the airstream is certainly going to create drag, which will kill your highway mileage.
That said, the new ford of mine certainly doesn't get the mileage that the 04 suburban it replaced did. I'm hoping as it breaks in it will get better but when the burb was brand new it got better than this...so...
Still, there are several things about the ford that I like better....just looks like I'll be eating more fuel cost.
Bill
05 scab lariat
Old Dec 23, 2005 | 11:06 AM
Rockpick's Avatar
Moderator &
I've noted my MPGs have dropped around 1.2 MPG recently.... I believe that's due to winter formulated gasoline though.
I'm averaging right at 14.2 to 14.5 with a 24.25 mile, one-way, trip into the office via 90% interstate. Mind you though, much of that interstate experience is stop and go like city traffic.
Old Dec 23, 2005 | 11:08 AM
Quintin's Avatar
I average 17-18 mpg on the display, but my morning commute is about 20 miles, mostly highway. I've also got a (relatively) fuel thrifty truck, a 4x2 Supercab with 3.55 gears.
Grubrunner's Avatar
Thanks.
I just, really, thought I'd be getting in the 14-16 MPG range with the type of driving I do. I can understand if it was city; but highway? Anyway .. .. ..
I'll be taking it on a trip to Nth Carolina (from Virginia) this coming weekend so I'll definitly reset the MPG and see how I go.
Thanks people.
Old Dec 23, 2005 | 11:24 AM
F150 Duke's Avatar
RP is right. Ever since we started getting winter gas up here in MN, which has been about 1 and half months, my gas MPG has gone down 2 MPG. It's been a horrible blow. I used to get roughly 340-370 per tank. Now it's more like 300-320. I think it also has to do with the truck needing to sit sometimes to warm up enough, and the fact that it won't let it go into OD without fully warming up. Those higher RPMs when you first start driving just suck down the gas.
Duke
Old Dec 23, 2005 | 11:25 AM
jpetre's Avatar
I keep the tach under 2 k and I usually get 14.5-15.2 city and when on the highway without my bike in the bed I get 18.5-19.1
Mods - AirAid Intake
Tire Pressue 40 lbs, 3.73 Rear, Screw 04, 4X4
Door says tire pressue at 36
Old Dec 23, 2005 | 11:32 AM
Wookie's Avatar
What speed do you drive on the highway? I have found that I get the best mileage when I keep it around 70. On long freeway trips 18+ is not uncommon. The best I have averaged was 20.2, between Little Rock and Dallas. I drove around 70 the entire trip and was easy on the loud pedal when I was accelerating. This week I drove from Little Rock to Lafayette La. and averaged 16. The trip was mostly on back roads and time was more important than gas so I was more aggressive with my speed and passing. This is with a bone stock KR Supercrew with a 3.73, and 18" LT tires. I have one on the heaviest trucks to leave Ford so I would expect my mileage to be the lower than most, if they were equally driven.
I would recommend checking your tire pressure and getting a reflash if you have an early build truck. Both of these helped my mileage significantly.
Joe
Old Dec 23, 2005 | 11:53 AM
04NickySP2's Avatar
Overinflated tires give you less traction because of how much tread is making contact with the ground.
I would fear a blowout if you keep the tires higher than recommended.
Old Dec 23, 2005 | 12:00 PM
inurok's Avatar
Mine MPG has never been lower than 13.5 and the best I ever got was 14.6 but I dont reset the meter too often.
Old Dec 23, 2005 | 01:15 PM
abadf150's Avatar
Im constantly at 13 mpg with 24" wheels. With the stock wheels the best I saw was 13.3 mpg.
