Keypad
Old Dec 20, 2005 | 03:12 PM
whaler417's Avatar
Keypad
I installed a new door handle with keypad on my XLT. The wiring harness was already in the door, and the new handle pluged in. I just took it to the dealership to see if they could activate it. They tried and said that my truck did not have the correct modual programing for key code. I guess now I have a cool looking door handle that won't work. Does this sound right, or is the dealership wrong?
Old Dec 20, 2005 | 04:32 PM
ChrisAdams's Avatar
I suspect the dealership just did not have a clue how to set it. On my truck there was never any possibility of 'turning it on' as my truck is an STX, no module, no harness, nothing.
I just installed an earlier analog module under the dash and did my own wiring, so mine is not 'purely decorative'. In your case you should find a more knowledgeable technician.
Old Dec 20, 2005 | 06:39 PM
whaler417's Avatar
keypad
Will check with another dealership. And they charged me $21 to hook it up to the computer.
Old Dec 20, 2005 | 08:14 PM
ChrisAdams's Avatar
After someone else turns it on, I would stop by with the recept and get my money back...
Best of luck with it.
Chris
Old Dec 20, 2005 | 08:25 PM
Matt 05'FX4's Avatar
Exactly....and that's what they gotta change . It can be done, just have to find someone that knows how.
Old Dec 20, 2005 | 09:17 PM
whaler417's Avatar
key pad
So the problem is that they have to reprogram the module? Just want to be clear when I go to another dealership.
Old Dec 20, 2005 | 10:25 PM
What my grandfather did when I put a set of LT handles on his truck is go to the dealer and tell them he wanted it programmed for a keypad, and they ended up taking the coding out of a truck with the keypad and loading it into his. Now to me, this makes no sense, you should be able to modify the original coding to match whatever options/accessories you have.......but I guess Ford does things a little differently than we do at work.
Old Dec 22, 2005 | 09:04 PM
04blkxlt's Avatar
whaler417
I am intrested in this mod for my truck. Where did you get the handle with keypad and was it easy to install? Keep us informed on your progress and how you get it programed. Good luck
Old Dec 22, 2005 | 10:39 PM
I have a stock handle with keypad if you want it.....he probably got the LT painted ones.
