Amp and Sub Question??
Old Dec 16, 2005 | 10:32 AM
Boataddict's Avatar
Can an aftermarket amplifier be run off of the audiophile headunit sub out?
The vehicle is a 2006 FX4 Screw.
Thanks,
Rob
Old Dec 16, 2005 | 11:09 AM
928gt's Avatar
Piece of cake.. Here is the connector Pin out.
Old Dec 16, 2005 | 01:42 PM
Boataddict's Avatar
So if I make a RCA adapter do I hook the + to the tip, the - to the ring and leave the ground float or do I hook the ground to the ring and leave the neg?
Old Dec 16, 2005 | 03:19 PM
928gt's Avatar
Yes. If you have some signal buzz you could use shielded 2 conductor cable and just hook the shield (pin 3) to the - (ring) on one end or the other to see which one eliminates the buzz. It is doubtful you will have that problem.
Old Dec 16, 2005 | 09:10 PM
Boataddict's Avatar
Thank you.
Old Dec 16, 2005 | 10:50 PM
Josiah's Avatar
Will this blow the rear 8" sub? What is a good aftermarket amp to get that will not blow my door speakers or my sub in the back. I would like it to fit in the same spot as my current 90w amp too.
Old Dec 17, 2005 | 08:18 AM
928gt's Avatar
Josiah,
??? The output fom the factory head unit "sub connector" is just a signal level, not amplified output so it would have no relation to blowing a sub or not (unless you turn it up so much you overdrive that output and cause massive distortion). The amplifier you use would determine whether or not your sub will get blown.. BTW, for giggles we used to hook up Big A$$ amps to some old 18" speakers (that were getting replaced anyway) in clubs and literally blow the cones across the room. We have also set large 8' x4' x 4' sub cabinets on fire by overdriving the speakers.. of course this was partially related to leftover sawdust in poorly manufactured cabinets (won't mention brand)
>What is a good aftermarket amp to get that will not blow my door speakers or my >sub in the back. I would like it to fit in the same spot as my current 90w amp too.
No clue on that one, the factory AP w/Sub setup is more than my ears can stand already.
Old Feb 11, 2006 | 11:57 PM
epovich's Avatar
Power Acoustics has a great 300 watt 3-channel(bridge for sub,+ left, - right)
Can find at MCM.com,summit racing, etc.
Old Feb 12, 2006 | 12:16 AM
nothinbutaford's Avatar
pin #4 may not be enough voltage to use directly as a remote turn on wire, I belive its only 5volts. You can use a pac tr7 to change it to 12volts or use the accessory wire.
