Chrome tips
Chrome tips
Hey guys...well its winter up here in PA. My dual exhaust is covered in roadsalt. My magnaflow tips are completely salted up...since they are stainless steel will they be alright or should they be cleaned off reguarly?
Unfortunately, the misconception is that Stainless Steal is invinsible since it does not "rust". However, stainless indeed susceptible to corroding and pitting. Chrome on the other hand has a coating, the thickness depends on the quality of the chrome, but is susceptible to rust if not cleaned regularly. The way to maintain either is to simply keep them clean using a wet rag and dry. No wax, no silicone based poishes, nothing. This is of course unless you like yellow-brownish SS tips becuase the silicone will burn off leaving behind a stain.
Originally Posted by silverbullet5.4
Unfortunately, the misconception is that Stainless Steal is invinsible since it does not "rust". .
Acutally, I think they are thought to be "invincible" : (n-vns-bl) adj. Incapable of being overcome or defeated; unconquerable.
as opposed to "invisible" (n-vz-bl) adj.
1. Impossible to see; not visible: Air is invisible.
2. Not accessible to view; hidden: mountain peaks invisible in the fog.
3. Not easily noticed or detected; inconspicuous: “The poor are politically invisible” (Michael Harrington).
4. Not published in financial statements: an invisible asset.
and I won't even comment on stainless steal as opposed to the more practical stainless steel
but you knew that...j/k
