High beam and fogs.....
Anyone try this product yet or know of anybody that did this mod on their f-150? I had something similar on my Denali from Stylinconcepts and worked well. I bought these off of e-bay for $13.00 so I figured I'd give them a shot.
https://www.f150online.com/forums/li...RK%3AMEWA%3AIT
take the cover off your fuse box. check your manual for the headlight relay. bend a leg out, connect a wire to it, ground to body- done, Hi's with fogs!!! gimme a sec, ill post the thread on it. 50c cost., 3 minutes
LOL...the kit said that other kits are just a wire without a fuse and "very unsafe"! Why would you need a fuse on a wire that your grounding????
Originally Posted by bdholsin
Just out of curiosity...why would you want high beams AND fogs on at the same time? Isn't it illegal? It is here in Michigan.
Not trying to talk you out of it...just curious to why.
Originally Posted by BalogUK
Thanks BalogUK! I havn't recieved the kit yet, but this looks very easy
I guess I should have done a search for this mod huh?
My bad!
I do alot of Driving at night on Rural roads as well, and any extra lighting helps a great deal. I thought about getting some sort of auxilary lighting but i'll try this first and see how helpful it is. I'm sure its illegal here in NY as well, but I will do my best not to be careless with it and blind oncomming traffic
Fair 'nuff.
boomer08 - You're right.
That is why they give us the dimmer switch. You know what I miss though...the dimmer switch on the floor. Without a manual transmission to drive my left foot gets bored while driving.
