No CEL throwing intakes?
Old Nov 30, 2005 | 07:59 PM
Cycleman6's Avatar
I will say that I have installed an AF1 and I couldn't be any happier with it. I have an 04 model, and the paraminters are set tighter on 04 than 05, so you are 'more' prone to throw a CEL in 04 because Ford had the parimenters set so freakin tight...However, I do have an 04 and have NO complaints on the AF1. Nothing IMO will look better than the T304 Polished Stainless Steel that Marc C. talked about. Pop the hood and 'bam' it's quite an impressive piece of engineering under your hood. I would recomend calling Troyer and going with the AF1/XCal2 combo. Heck of a deal on the combo price. I did, and don't regret one thing.
Old Dec 1, 2005 | 12:22 PM
I like the look of polished metal under the hood as well, there is far too much plastic in the engine bay.
Old Dec 1, 2005 | 01:50 PM
Josiah's Avatar
I must have missed that deal. My AF1 just arrived and is sitting in my lap, can't wait to install it, I promise I'll post pics and/or video as well as a review after evaluating.
Old Dec 1, 2005 | 08:17 PM
jimmy k's Avatar
Originally Posted by khendrix2374
EDIT: Troyer Performance stated that after R&D that K&N had little or no gain in performance, just sound.
How much gain did Troyer claim that K&N puts out? How were these results obtained? K&N's dyno say's 15.47. They've been around for "quite" a while, I would tend to trust them before anyone else.
K&N GUARANTEES HP or your money back.
Keep in mind, I don't favor anyone in particular. I have a K&N intake and a Troyer X-cal. I also have full confidence that my intake will NOT throw a CEL
Old Dec 1, 2005 | 08:31 PM
jimmy k's Avatar
Originally Posted by Quintin
As far as it being damaging, well, unless it's in extreme cases (like WOT dyno pulls), I don't think the engine will run lean enough to cause damage. Maybe the Troyer guys will say otherwise, but I'd figure the PCM would revert to a failsafe mode just puttering around town that'd run on the richer side of lean to prevent any possible engine damage.
Thanks Quintin, I asked that question a while back and never received an answer.
Old Dec 1, 2005 | 08:51 PM
boomer08's Avatar
I have an Airaid and had the light come on then I called Airaid and they sent the updated intake and no problems since.
Old Dec 2, 2005 | 04:48 AM
Josiah's Avatar
I just installed my AF1, no CEL after 45 miles or so
Old Dec 2, 2005 | 07:51 AM
kdds05screw's Avatar
Go with the Airaid or AF1. You might as well go with an intake with proven performance on the new F150's. I've had Airaid on for 6k, no problems and would have installed either but I personally don't care for any chrome/polished stainless parts on my truck. ( .. first mod I did was remove the chrome side steps and installed running boards ! ) Airaid had a slight drone sound at 1800rpm but went away after Troyer xcal2 tune was installed.
Old Dec 2, 2005 | 08:40 AM
04Triton5.4L's Avatar
had my Airaid for 15k and no CEL. You can sometimes find them on sale if you dig around the internet. I found mine for just over $200 + shipping.
Old Dec 2, 2005 | 08:50 PM
rdblan2's Avatar
Seemed to be touch and go with come of these intakes. Some guys got them with the AF1s and Airaids, I think most didn't though.
I went with the K&N, just got my K&N FIPK for my 05 the other day. Probably won't be able to install it until about X-mas time though.
Old Dec 3, 2005 | 10:30 AM
I think I'm going to hold off on anything for now, I need to save money for the Troyer stage 1 kit. I don't think I can go wrong with that.
Old Dec 3, 2005 | 11:11 AM
Newt's Avatar
Originally Posted by Marc Carpenter
#1 Airforce 1 is polished stainless steel and will NOT tarnish or dull.
#2 The stainless steel does NOT hold more heat than plastic.
( I took part in R&D'ing this issue)
#3 The reason K&N does not cause any CEL's is because it does NOT allow
nearly as much airflow as the Air Force 1 .
#4 The closest CAI to the AF1 in performance is the AirRaid.
Marc
Was the Volant tested?
Old Dec 3, 2005 | 11:19 AM
kd4crs's Avatar
Not long afterward...
I have joined the CEL club and it goes on everytime I reconnect the battery <snip>
That didn't last long did it? Seeing that CEL come on sure is a killjoy. I had the same experience with the one I bought (and sold).
Old Dec 3, 2005 | 01:15 PM
SoundPer4mance's Avatar
i have the volant on mine, no problems at all has a filter box to keep hot air out, and actually looks like it belongs under the hood. also one of the quieter intakes, compared to others
