swapping diff and gears ?
Old Nov 26, 2005 | 10:29 AM
MyVersion's Avatar
I am swapping out my non LS rear for a TrueTrac and some 4.10s.
What am I going to need to do this. Should I get the "master install kit" for installing a ring and pinion and diff. Any suggestions or comments would be appreciated.
M V
Old Nov 27, 2005 | 09:15 AM
MyVersion's Avatar
anyone
Old Nov 27, 2005 | 10:36 AM
Quintin's Avatar
You'll need the differential assembly and ring and pinion. Along with this, you'll need pinion shims, carrier shims, a new crush sleeve, and a new pinion nut. Replacing all the bearings and races (front and rear pinion, carrier and maybe axle) would be advisable as well. The shims, crush sleeve and pinion nut should come with a new ring and pinion.
Old Nov 27, 2005 | 03:59 PM
MyVersion's Avatar
Cool, thanks for the info. I am pretty sure all of the above listed are included in the Master Install kit.
Thanks again
Later
M V
Old Nov 27, 2005 | 05:55 PM
asinatra's Avatar
Thanks again
Later
M V
You can't just swap gears without knowing exactaly what your doing
Old Nov 27, 2005 | 09:39 PM
etrevino103186's Avatar
I tryin to figure out what to tell the people so I dont sound like an ****. Right now if I were to power break only one will break lose. That is non-LS correct?
Old Nov 27, 2005 | 09:48 PM
khendrix2374's Avatar
Correct.
If you find someone that is experienced in doing gear swaps and rear end work... they will understand what you want.
Old Nov 27, 2005 | 09:52 PM
So with LS both of the will turn? Any other differences? Noise, mpg's, handling, power? I am not even sure if I need it but my friends rag on me cuz I don't have it.
Old Nov 27, 2005 | 10:02 PM
It's not that simple... If you had a LS diff, and you put one foot on the brake and mashed the gas, both will spin.
Noise. No difference
MPG. No
Handling. NO
Power. NO.
Do a google search for limited slip stuff and lockers and stuff like that... You'll find better info than you will here.
Old Nov 28, 2005 | 11:06 AM
bigtruck311's Avatar
i asume you are having a shop do the install, if you are asking what you need to install it if you plan on doing it yourself i highly advise you to have someone there that has done a ring and pinion there to guide you it is a lengthy process and must be perfect, you will also need a few speceal tools that the everyday mech does not have a micromiter caliper, a bearing press(not exactly needed you can use a hot plate and a freezer but this does not always work) a magnetic base dial indicator for mesuring backlash, if you are paying a shop to do it you will only need the master install kit the new ring and pinion and the diff ***. that you plan on using, and if it is 4x4 you must change the front ring and pinion to match the rear, good luck
Old Nov 28, 2005 | 11:15 AM
04NickySP2's Avatar
I made an excel spreadsheet to figure out rpm/speed. The link is in my sig below.
Old Nov 28, 2005 | 08:30 PM
MyVersion's Avatar
from Asinatra
I now this, that is why I am posting this thread.
bigtruck311, 04NickySP2, khendrix2374, thanks for the info I appreciate it.
Last but not least Asinatra, thank you for popping in.
I was going to attempt this but I think I will have a shop do this for me
now.
Thanks guys, I appreciate it.
Later
M V
Old Nov 28, 2005 | 08:36 PM
asinatra's Avatar
It is easier to spin out w/ LS considering both wheels would have foward motion instead of just one
Old Nov 28, 2005 | 09:43 PM
MyVersion's Avatar
Very true, which makes it even more exciting/fun to drive.
I love going sideways.
How come you never see any trucks entering any Drifting contests.
Later
M V
