For those who removed their rear blocks???
OK, I removed my rear blocks from the SCREW. I purchased the 2wd u-bolts since they work perfect for the removal. My question is has anyone had vibration issues after doing this mod? I am trying to figure out if my tires are vibrating now, or is it my drive line. It happens around various speeds. I unfortunately can't remember how it was before the removal :o
I have had no issues on mine since removing the blocks last spring. I read a post at least 10 months ago that the block removal changed the pinion angle less than 2 degrees and does not require any adjustment.
Mine did seem to be a little more bumpy afterwards on washboard type surface. Could have been the diff in the shock positioning. I have put my blocks back in and replaced my shocks and it's better than ever now.
Well since I was off today I put the blocks back in, no more vibration...
I may purchase some shims later on to go back down with it. I have the shims in the GF shackle kit I bought, but I do not want to break that kit up since I am trying to sell it.
