Tire Rotation
Old Nov 20, 2005 | 06:54 PM
RUSS04's Avatar
Tire Rotation
I have a 2004 SUPERCREW LARIAT 4X4 with Goodyear LT275/65R18 Wrangler at/s The truck has 5415 miles on it I know that the tires should have been rotated at 5000 miles I have no shimmys,vibes the front tires look like the rear no wear Iam just a little worried if i rotated the tires and by me doing this My front end might get a shimmy,vibes Should i let the tire rotation go until 10000 miles ?
Old Nov 20, 2005 | 07:01 PM
Quintin's Avatar
I don't think there'll be enough practical difference to matter if your alignment is on spot. I rotate mine every service, and balance every third service.
Old Nov 20, 2005 | 07:04 PM
ATCS2004's Avatar
I rotate mine between 5-6K miles. It won't hurt anything to rotate them now. I would not wait until 10K.
Old Nov 20, 2005 | 07:55 PM
worland's Avatar
6000 miles seems to be the new magic number for rotating tires under severe use. At least that's the number on the last couple of tire warranties I have. I've always waited until 10,000 miles unless I start to notice some uneven wear. Fords tend to wear the outer edge of the front right tire.
Old Nov 20, 2005 | 08:17 PM
Matt 05'FX4's Avatar
I change oil every 5K (mobil 1) and rotate tires when I do that just to keep em wearing good. I have balanced 2 times and have 20K on my truck and the tires still have a LOT left!
Old Nov 22, 2005 | 07:25 PM
RUSS04's Avatar
Thank you for your replys I will rotate tires this weekend and let you know the results
