Fuel Pump upgrade
Old Nov 1, 2005 | 03:21 PM
gmanjerseyfx4's Avatar
Fuel Pump upgrade
long story short, im looking to upgrade my fuel pump to a 255 LPH pump...what should i go with internal or external of the fuel tank...any input would be appreciated...thanks!
Old Nov 1, 2005 | 03:42 PM
Marc Carpenter's Avatar
Okay, I'm curious. Why are you upgrading????
Old Nov 1, 2005 | 04:03 PM
reason being: Im installing a Procharger kit shortly...the kit does not come with any fuel system upgrades other than injectors and supposedly the kit leans out A/F in higher RPMs on SOME trucks...so i want to prevent this problem before i run into it as this truck is my daily driver...HELLP
Old Nov 1, 2005 | 10:40 PM
takotruckin's Avatar
if possible i would use a stock replacement in tank. an inline would probably make plumbing difficult
Old Nov 1, 2005 | 11:09 PM
asinatra's Avatar
dual svt focus pumps or dual aviators work too
Old Nov 2, 2005 | 09:55 AM
Has anyone done the upgrade on a 3V motor??
Asinatra,
where would i get those? do they work for sure on the 3v application?
Old Nov 2, 2005 | 12:49 PM
asinatra's Avatar
We'll since 98+ its all been returnless style fuel systems so i dont see why they wouldnt work
Old Nov 2, 2005 | 01:09 PM
DevilSun's Avatar
Agreed with asinatra here...any returnless style fuel system pump(s) will work. I'm sure there are people out there who have done that stuff on the newer 3V mustangs, but even so, it's been around since MY99 I believe.
Old Nov 2, 2005 | 02:06 PM
o ok thanks guys...i didnt no the returnless systems went back that far...thought it was just the newer model...ive come across some higher output fuel pumps for the mustangs...so given that it is essentially the same fuel system, any reason these pumps wouldnt work if rigged into my fuel tank?
Old Nov 2, 2005 | 02:44 PM
svt03lightn's Avatar
Us Lightning guy's use the 255 pumps all the time, Contact JLP he has them.
Old Nov 2, 2005 | 02:48 PM
Jlp???
Old Nov 2, 2005 | 03:43 PM
Smokeneck's Avatar
Jlp???
Johnny Lightning Performance, I believe.
Old Nov 2, 2005 | 05:33 PM
are the pumps plug and play?? or do you have to do any special modding to get them to work right??
Old Nov 10, 2005 | 02:48 AM
madferraristi's Avatar
F-150 trucks are "return" type systems up through 2003, take a look, you have two lines on the fuel rail, one supply, one return.
Be careful installing Lightning fuel pumps on a standard F-150, the Lightning has a dual voltage system that runs the pumps at 8 volts up to about 2/3 throttle then the voltage rises to the full 12. The effect of this is that it reduces the fuel flow when it is not needed. If you run the "L" pumps at 12 volts at idle, the fuel pressure will rise due to the fact that the return line is not large enough to handle the amount of fuel returning to the tank.
Been there done that.
