Climate Controls
Old Oct 21, 2005 | 09:18 AM
Krohbar's Avatar
Climate Controls
Ok, here's one for you. Provided that you replaced the center trim piece, can you install the Auto Climate Control from a Lariat into an FX4? Plug and plag with the brackets behind the dash?
Old Oct 21, 2005 | 10:14 AM
asinatra's Avatar
One of them is, the second harness you will have to make. As well as loose your fx4 IC
Old Oct 21, 2005 | 11:21 AM
Krohbar's Avatar
Fx4 Ic?
Old Oct 21, 2005 | 11:27 AM
wstahlm80's Avatar
Originally Posted by Krohbar
Fx4 Ic?
Information Center?
I believe the Climate Control is integrated to the computer display that only comes with the Lariat option....
Old Oct 21, 2005 | 11:37 AM
04NickySP2's Avatar
What IC in the fx4? I wouldn't consider a compass an IC.
Old Oct 21, 2005 | 12:31 PM
SteveVFX4's Avatar
It tells you when your door is ajar, that's some good info!
Old Oct 21, 2005 | 12:50 PM
Lizardking's Avatar
I had a SHO Taurus and a Continental with the EATC. The wiring and components were completely different than the same vehicles with manual controls.
The EATC is cool when its new and it works. Down the road when they go bad its $$$$$$$$$ to fix them. Trust me the manual controls are the way to go.
