CA 670 install
Old Oct 5, 2005 | 06:42 PM
countyboy04's Avatar
CA 670 install
I plan on installing my CA670 either this weekend or next. For anyone who has installed their own unit, do you have any tips or anything to watch out for. I have seached through the forum and have got a lot of good info but more info I have the better. I got the pre-wired system from autoalarmpro.com.
One question to start things off, where is a good place to mount the pats module? Maybe zip tied to something under the dash?
I will also be adding a window module that will roll the front windows up and down. If anyone has installed one of these your input would be much appreciated.
Old Oct 5, 2005 | 09:02 PM
asinatra's Avatar
Mount the brain next to the BCM/VSM, the PATS module in the cubby hole next to the IC, youll see it when you take the IC trim off.
Old Oct 5, 2005 | 09:10 PM
What is the IC? Is the BCM/VSM located next to the battery?
Old Oct 5, 2005 | 09:16 PM
asinatra's Avatar
IC = Intrument Cluster, not to get confused with IP (Instrument Panel) which is technically your whole dash.
VSM = Vehicle Security Module
BCM = Body Control Module
This in your case is located behind your rear seat and will have every wire you need access to except remote start wiring.
Old Oct 5, 2005 | 09:20 PM
Does the instrument cluster have to be removed?
Old Oct 9, 2005 | 10:45 PM
golferdude1971's Avatar
What is the two-way remote's range(in feet)?
Old Oct 10, 2005 | 02:27 AM
02SuperCrew4X's Avatar
I have an Audiovox remote start, and my 2-way remote's range is about 1400'.
