New Wheels, Tires, Shocks and Coilover
Old Sep 30, 2005 | 12:00 AM
TrukMupper's Avatar
I got my Rancho 9000XXX coilovers for $103 each + shipping at O'Reiley. They had to order them. It cost me $289 at the dealership to install them and realign the front end. I set the height at about the middle of the range myself and got with 1.5 " of lift. Came out exactly like I wanted it to. Haven't had time to post pics yet.
Old Sep 30, 2005 | 12:05 AM
hwm3's Avatar
I'd like to see some pics of the coilovers themselves if you can.
Old Sep 30, 2005 | 12:37 AM
TrukMupper's Avatar
I'm not sure how to post pics in the thread but you can see what they look like in my gallery link under my profile. The adjustment sleeve and spacer are pretty visible.
Old Sep 30, 2005 | 12:51 AM
higdogg's Avatar
Originally Posted by CarlJ
Look's great! How bout some info on the coilover's. I have wanted to level my truck out a little bit, but don't like the spacers. I think they make them to high in the front, which makes the back look like it's sagging. I still want some rake, just not 3" of it.
CarlJ,
What does 30mm offset equal to? I know I want about 4.5" backspacing when I get wheels (I think) so that it will stick out further. I'm afraid if I get any less backspacing than 4.5 when I run 33's that it won't stick out very much at all. Yours looks good, if it were my setup I'd probably run a little bit fatter tire if possible, so you can get an idea of what I like and want.
Old Sep 30, 2005 | 12:53 AM
Justins FX4's Avatar
so you cant adjust them after you get them on?. not even if you jack the truck up?
Old Sep 30, 2005 | 01:06 AM
TrukMupper's Avatar
Nope. I tried it for myself even though Rancho told me you couldn't. The coil spring just puts too much force on the spacer to allow it to move. It's pretty easy to get just the amount of lift you want though. Just measure both sides exactly the same with a ruler from the top of the spring seat to the bottom of the sleeve.
Old Sep 30, 2005 | 03:58 AM
mlawdawg's Avatar
Thanks for all the comments fellas. Justin, how do you like those 4.56 gears? That's one of my next mods.
Old Sep 30, 2005 | 04:06 AM
mlawdawg's Avatar
Originally Posted by higdogg
CarlJ,
I believe he is at 5.5 backspacing. Backspacing - 1/2 of wheel width = offset. You can convert mm to inches by dividing by 25.4
Old Sep 30, 2005 | 08:09 AM
im still saving up to get some gears its my next major mod. but i'll let ya knoiw
Old Sep 30, 2005 | 01:43 PM
oscar_a_wiggy's Avatar
this sounds like a perfect choice for somebody that wants to run 33 x 12.5 tires on after market rims and not use the skyjacker lift or the auto spring.
good info
Old Sep 30, 2005 | 02:11 PM
CarlJ's Avatar
CarlJ,
Mlawdawg is right. It's about 5.7" of backspacing.
Old Oct 3, 2005 | 09:00 AM
i went to rancho and 4 wheel parts websites and cannot find any info on these. are they that new?
Old Oct 3, 2005 | 09:17 AM
dzervit's Avatar
Looks real good!
Old Oct 3, 2005 | 09:36 AM
mlawdawg's Avatar
I have seen them in the Rancho catalog. If you go online you can download it and find them there. I have not seen them listed on any of the major websites. I had my 4x4 guy call his ditributor for them. You keep the factory coil and these go inside with an adjustable collar. Works great.
Old Oct 6, 2005 | 01:35 PM
here is the ordering info from rancho tech e-mail
"I do offer a new series shock that has an adjustable spring seat called the
RS9000 Triple X. Its designed for the new body style Ford F150's not the
2004 Heritage body style. The part number is RS99768."
do you guys think the same a-arm rubbing problem will occur with this adjustable coil-over that happens with the autospring?
oaw
