Anyone know how I can route some wires up the A-Pillar and under the headliner into the box on the rail system in my 04 F-150 Screw ? I'm guessing It would be easier to route it through the lighting up front and dremel some holes into the boxes on the rail. Any suggestions on this would be much appreciated.
I fished a wire from my 3rd brake light to my a piller. It was a piece on cake. Used my fiberglass "fishstix". So I what think from the piller to the box whould be a cake walk too.
You do mean over the headliner right?
Yes im talking about above the headliner just trying to figure out if there are going to be any problems when fishing i.e. clamps clips anything in the way.
How do I take the light down off the front ? I looked at it and I dont see any screws so i can only assume that something pops off and reveals screws or the whole thing pops off from clips.
Need help quick my truck is all apart. (well not ALL apart)
if you have a 05 or newer there is a vacant 12V aux power harness above the first bin. if you want speaker or radio wirew routed up there it is quite simple to run wires up the a pillar then along the front edge of the headliner ( tuck under the headliner) then above the rails.
to get the front console down, remove the first bin and tug quickly at the back edge of the console, there are 4 spring clips.
if you want to do it right, there are frequent small holes in the A pillar steel and front header steel to push christmas tree fasteners in that are taped to a wire harness.
Ramb
Ramb
