How bad was your alignment out after autospring install?
Old Sep 26, 2005 | 12:36 PM
ptownfire's Avatar
Registered User
Installed mt 2.5 autospring friday and had it aligned. The tech at the shop told me that my toe was the only thing out. Those of you that have installed an autospring, what was out of alignment with your trucks? Maybe its my mind playing tricks but it feels like my truck is all over the road.
Old Sep 26, 2005 | 12:39 PM
RED WING NUT's Avatar
The toe was only thing out. It still drove perfectly straight before the alignment.
Old Sep 26, 2005 | 01:37 PM
wheelerfreak's Avatar
My toe was also out of spec. It drove and tracked fine after the 2.5" AS kit. It still rides fine and doesn't wander all over the road.
Old Sep 26, 2005 | 01:58 PM
05supercrew's Avatar
Mine tracked fine also and had a slight shake around 40 mph. the alaignment was off alot. They gave me a computer print out showing me. The truck rides straight now.
Old Sep 26, 2005 | 02:22 PM
garscott's Avatar
Installing the autospring made my front end a little more stiff, which seemed to magnifiy a tire out-of-balance I didn't know I had. Got my tires road forced and all is good now. Pulling to one side is usually an alignment issue, but can also happen via tire pull. Seems like you would have noticed that before though...
Hope you find the problem.
Gar
Old Sep 27, 2005 | 11:22 AM
DevilSun's Avatar
It may not look out of alignment, but the guy commented saying "Wow, good thing you came in, that was WAY off"...I replied with "Well, I just a put a 2" leveling kit on it", he smiled and shook his head and said "no biggie then because it's perfect again". Theoretically the toe will be quite screwed up...it's not possible for it not to be.
Old Sep 27, 2005 | 11:27 AM
mslc1's Avatar
shop said minewas ok...no problem.
Old Sep 27, 2005 | 11:41 AM
I took my truck to sears first and they said because of the lift they cant/wont do the alignment. After that went to goodyear and there was no problem.
Old Sep 27, 2005 | 03:21 PM
KSpencer's Avatar
I also found it difficult to get someone to align it after the install (1.5 inch). Only after calling the 4th local shop and telling them what was going on did they agree. Must be something to do with installing my own parts and they would not touch it. Anyway...I cannot feel any difference in ride, steering, or alignment problems from before and after.
Old Sep 27, 2005 | 06:08 PM
tele's Avatar
i took mine to a front end/spring specialty shop. didn't tell them about the lift just told them it was brand new and wanted to check the alignment. the toe was out and everything else ok. the truck tracks perfectly.
Old Sep 27, 2005 | 06:21 PM
Cypress700's Avatar
Just toe out somewhat on mine,Ride will be stiffer due to springs being preloaded a bit.Tech that did the alignment mentioned the ball joint angle may cause excessive wear on them.Sure is nice to be level !!!!
Old Sep 27, 2005 | 06:54 PM
poptop's Avatar
mine was only slightly off had no problem getting a local shop to liner up cost 48.00.i love the lift worth every penny feels like a different truck
Old Sep 27, 2005 | 06:59 PM
freekyFX4's Avatar
The tow was off. Mine rode like new after the alignment. The truck only rode a little worse after putting 13.5" wide tires on it. If you put bigger tires on the truck, that may be what is causing the tracking problems.
Old Sep 27, 2005 | 07:03 PM
SuperCrewAg's Avatar
You guys didn't have to put a 'cam kit' on it? My alignment was off a good bit and the guy said it had to have a 'cam kit' put on so that he could adjust the camber. He said the right front end is at max camber and it is slightly out of perfect spec., so it tracks a little to the right if I'm on a crowned road.
Old Sep 27, 2005 | 07:11 PM
ThumperMX113's Avatar
Hmm, I don't know how you guys say it drove like normal. I had put it in, got it aligned, and had to take it out for a trip to the dealer and whenever I would turn hard my front tires would squeel like they were sliding out.
