Truck would not start....
Old Sep 22, 2005 | 11:11 AM
Stragum's Avatar
Yea Minus 13 I am keeping a running log on it for sure. Each time it happens I am also calling Ford and letting them know about it.
They have a ticket on me that was left open from last week, so I called this morning and they documented it too.
Man, I am praying that a solution can found soon. It's just frustrating. I had a 2000 F-150 and had absolutely no problems with it and now with my '05 FX2 this is the only lingering problem I am having.
Thanks guys for your ideas and suggestions. I will also keep a running log here if it keeps happening again.
Old Sep 22, 2005 | 08:59 PM
minus_13's Avatar
bump for the night crew...
Old Sep 22, 2005 | 09:06 PM
2nd_wnd's Avatar
i had that happen to me several times as well. the first time i took it to the dealer they reprogrammed computer. it happened twice more in less than a week. the last time they change the throttle body, been 2 weeks and no problems yet.
Old Sep 23, 2005 | 11:00 AM
Stragum's Avatar
thanks 2nd_wnd
Old Sep 23, 2005 | 11:08 AM
GrizfromKY's Avatar
I was having the same problem a while back. I took it in and all they did was reflash my PCM. It hasn't happened since. Maybe that would help you.
Griz
Old Sep 23, 2005 | 11:09 AM
Stragum's Avatar
Ok. What is PCM?
Old Sep 23, 2005 | 11:41 AM
GrizfromKY's Avatar
I'm not positive what the acronym stands for but it is the computer that controls many different parameters of our trucks.
Old Sep 26, 2005 | 01:59 PM
Stragum's Avatar
Okay after three people here suggested that it could be the key that I am using that perhaps the cpu in the truck is not recognizing the key that I am using.
Anyway, I exchanged keys with my wife this morning (9/26/05) who had my other one, so wish me luck and we'll see how it goes.
Thanks again guys for your many suggestions.
Old Oct 3, 2005 | 12:01 PM
Stragum's Avatar
Ok guys! Today is the 8th day (10/3/05) since I switched keys with my wife. This is the longest I have gone without any "bad starts", so wish me luck and say a little prayer that the key was the answer.
Could it have really been the answer? That maybe my other key doesn't register properly with trucks cpu?
My fingers are still crossed!
For those who suggested and all replies, I am buying you a cold frosty one today my friends!
Old Oct 10, 2005 | 08:49 AM
Stragum's Avatar
Okay guys today marks 2 (10/10/05) weeks since I switched keys. Thats 14 days and no bad starts.
Whooopeee!
Hope it the streak continues!
Old Oct 10, 2005 | 01:15 PM
C-17 Pilot's Avatar
I experienced the no start issue for the first time yesterday. I had driven the truck about 15 miles with no problems, parked it for about 45 minutes, then tried to start the engine. The engine turned over twice, then just stopped dead. At first, I thought perhaps I had just released the key too soon, so I waited about 20 seconds (for starter cooling), then tried again. This time I was sure to hold the key in the start position--but it did the same thing. The engine turned over approximately twice, then just stopped dead. My wife (who was outside the vehicle when I attempted to start the truck) said she heard what sounded like a metal-on-metal sound just before the motor stopped, but I could not verify this from inside the cab. On the third attempt it started up just fine and has been running great since then.
After doing some research on this forum, I think the issue can be fixed with TSB 05-18-9. My truck's build date is 04/04/05, so I probably need the latest PCM flash anyway. My plan is to have the dealer do the flash the next time I take it in.
C-17 Pilot
Old Oct 10, 2005 | 01:56 PM
MIGHTY 150's Avatar
had this happen to me today 10-10 again after at least a 3 week non occuring period. here's the kicker out of these 2 incidences i have washed the truck in one of those touchless wash bays. 1st time the no start actually did it right there in the bay, todays actually happened several hours later. very strange but indeed you aren't the onlt odd ball out there. for the people who have/had this problem. what is your build dates? mine is 07/05
Old Oct 10, 2005 | 03:12 PM
C-17 Pilot's Avatar
This is interesting. I did not take my vehicle through a car wash, but it had been raining during my drive prior to the no start. It was also one of the first cold days we've had here, so I thought the cold might have been the issue, but now I'm wondering if something is getting wet under the hood? BTW, I've driven it in the rain before with no prior problems.
Build date is 04/04/05. 5.4L, 3.73 LS, 4x4, Supercrew FX4
Old Oct 10, 2005 | 03:28 PM
MIGHTY 150's Avatar
yah, i've driven through rain as well w/ no adverse problems either.it is sure a weird mishap. also keep a log on your fill-ups as well. i just got gas sunday...
i'm going to stay away from that car wash and see what happens,it's just to starnge that both of the times this has happened i washed the vehicle at that car wash...
Old Oct 12, 2005 | 09:18 AM
kd4crs's Avatar
Originally Posted by Stragum
Ok. What is PCM?
Powertrain Control Module.
