MagnaFlow Ordering Question
Old Sep 16, 2005 | 03:28 PM
Devin4X4's Avatar
Hey guys...i know im going to go with magnaflow just not sure which one. I really want to get a SIDO magnaflow duals STRAIGHT out the back. I cant find that anywhere!! Could someone point me in the right direction. Everywhere i look the make the SIDO rear side exit...thats not what i want.
Old Sep 16, 2005 | 06:44 PM
Blazin5.4's Avatar
I'v seen them on ebay, but why not try google or even better magnaflow.
Old Sep 16, 2005 | 07:20 PM
RED WING NUT's Avatar
http://www.magnaflow.com/02product/s...e=Trucks&id=67
or
http://www.magnaflow.com/02product/s...=Trucks&id=957
depending on when your truck was built.
Old Sep 16, 2005 | 07:24 PM
dzervit's Avatar
http://www.hottexhaust.com/Ford_Truc..._Magnaflow.htm
Add the kit you wish to your cart and use the coupon code: fordtruck8
Old Sep 16, 2005 | 07:53 PM
Devin4X4's Avatar
just thought of something....i have the factory OEM trailer hitch, and in the install directions, it says that the dual exhast system may not work with some OEM trailer hitches. Does anyone know if i'll have a problem? thanks
"*May require modification to fit on vehicles equipped with trailer hitch." this was on the website.
What kind of mod would i possibly have to do?
Old Sep 16, 2005 | 08:03 PM
Devin4X4's Avatar
heres the system i want...
http://performancepeddler.com/detail...CT_ID=MAG15834
it says DUAL SPLIT REAR EXIT, but the picture shows it coming straight out the back. is that what it means?
Old Sep 16, 2005 | 08:29 PM
kd4crs's Avatar
The work-around for the hitch in the way problem is to drill and tap the frame on the outside of the frame just ahead of the hitch. Use the hanger bracket for a template to mark where to drill. Then bolt the hanger to the outside of the frame with hanger pointing in toward the spare tire. This work-around also increases te clearance for the spare tire somewhat.
Old Sep 16, 2005 | 10:15 PM
Tical84's Avatar
Note where the photo says "Sorry, at this time an actual photo is not available"? I'd go with the text and say its split rear, but that's just an assumption
Old Sep 17, 2005 | 11:23 AM
Devin4X4's Avatar
Well...looks like im going to order the dual 15834 from hottexhaust.
Thanks for that coupon code dzervit...save me quite a bit of $$$.
