20s or nav
Old Sep 7, 2005 | 04:03 PM
bofer's Avatar
i got the helo's but after i got those i gave a call to my tire guy and was about to order some tires, 325 60 18, i was wanting to go with a mickeythompson, but he said they will wear out fast, i love the look of them but i want some miles out of my tires. so the next tire was the terra grappler. yeah, those are on back order for who knows how long. so now im stuck with the toyo MT, i havent ordered them yet, just the rims so far, you guys have any suggestions as to what would be a good tire in a 13 inch wide tire? i might just ride with those rims on the stock tires for a couple of months till i can get ahold of some terra grapplers anyway, what do you guys think
Old Sep 7, 2005 | 04:43 PM
ThumperMX113's Avatar
If you can get the Toyo M/Ts, I'd get them. I was going to get them but they were on backorder at the time so I just opted for the Nitto TGs.
Old Sep 7, 2005 | 05:20 PM
bofer's Avatar
im just worried about them being loud on the highway. ive herd they are quiet but im used to BFG At, prolly alot quieter, what do you think
Old Sep 7, 2005 | 05:34 PM
I'd only worry about it if you don't listen to your radio.
Old Sep 7, 2005 | 08:16 PM
bofer's Avatar
so, can i fit a 35x12 50 toyo MT on these 18x9 helo rims with my 2.5 leveling kit, or will i have to stick with the 33s?
Old Sep 7, 2005 | 08:25 PM
freekyFX4's Avatar
The Mickey Thompson Baja ATZ's are very quiet. I have the 325/50R20's.
Old Sep 7, 2005 | 09:41 PM
Your going to have to stick with a 33.
Old Sep 7, 2005 | 10:52 PM
bofer's Avatar
that sucks, just curious, how come you can do it with the eagle 178s and not the helos?
Old Sep 7, 2005 | 10:53 PM
Just the way the backspacing is, I guess.
Personally this is the judgement that is fool proof. If your using aftermarket wheels stick with 33s and if your using stock wheels use 35s. Considering your using a leveling kit for both scenarios.
Old Sep 7, 2005 | 10:57 PM
bofer's Avatar
of course, the 2.5, im just bumbed i cant do a 35, those toyos would look so BA in the 35.
well, any word on how the mickeythompsons hold the the ATZs, from what i uderstand, mickeys are soft rubber and will wear out really fast, is this true?
Old Sep 7, 2005 | 11:02 PM
I really think you'll be VERY pleased with the 33 Toyo M/Ts. I can't speak for the Micky Ts because I've never owned any.
Old Sep 7, 2005 | 11:11 PM
bofer's Avatar
i guess so...im just a little bummed, o well, thump, did is there a nice ride increase from the stock height with the new rims and tires, or is there not the much a diffrence. that was the main reason i wanted the 35s, just beefier and they would give it a higher stance
what would i have to trim to fir the mickeythompsons 325 65 18 its like a 34" tire on those helo rims 18x9. there has to be something, where there is a will there is a way right? there has to be
wow, this must really show you guys i dont know what i want could i fit a toyo mt tire i think it comes out to like a 35x12.50x18 with some triming? Basically, i "want" either the 35x12.50 toyo mt or the mickeythompson in a 325 65 18 (34"). If this isnt at all possible with some trimming, then i will go with the mickeythompsons in a 33, but there has to be a way a narrower tire will fit or a slightly smaller tire?
Old Sep 8, 2005 | 12:49 AM
2000F150HD's Avatar
I think you could run the 35" tires if your backspacing is just right. I have heard that the MB wheels are perfect... 8.5" wide with +30 MM offset. The problem with this is that most if not all 35" tires reccomend a wider rim than this. But it will work. But, If you already have the Helos you might be out of luck for the 35" tire. I personally think it is a better overall idea to go with 33" tires anyway unless you get it lifted. Consider that your effective gear ratio will go to around 3.40 with 35" if you have the 3.73 stock. For me that is too low because of towing and hauling. But might not be an issue for you. Let me know how you like the Toyo MT as i am probably going to order them next week.
-stephen
Old Sep 8, 2005 | 10:02 AM
freekyFX4's Avatar
Originally Posted by ThumperMX113
They'll fit fine, my tires are 325/60/18 which comes out to equal a 33x13.50x18. The only part I had to trim was a little bit of the black fender on the left side and part of the fender flare. I'll attach a picture to explain it better, it only took me about 5 minutes with a wiz-wheel. I never noticed it until I started to backup to my shop to unload the stock wheels and I heard it rubbing. Did you order the Helo Maxx 6s or the Eagles?
I hope that helps you out bud!
When I installed my new wheels and tires, they only rubbed when backing up with the wheels turned or taking a large bump with the wheels turned. I trimmed the exact same thing that you did and no more rub. I just used a pair of "nippers" like this to do the job:
Old Sep 8, 2005 | 10:13 AM
Yup, like I said it only happened when I was backing up.
