Modding stock intake
Old Sep 5, 2005 | 08:56 PM
badkarma38's Avatar
Has anybody played around with modding the intake tube on a 5.4?? I read that a guy modded one on a 4.6. Also what would happen if you cut off the 2 baffles that are on the stock tube, wouldn't that straighten out the airflow?? Finally, does anyone know of a good website that deals in plastic tubing and hoses. I'm looking at making a CAI using existing parts and a drop in K&N.
Old Sep 5, 2005 | 09:02 PM
kd4crs's Avatar
Old Sep 5, 2005 | 11:09 PM
badkarma38's Avatar
The chambers on the sides of the tube, are they sound baffles or something else. What would happen if you were to cut them off???
Old Sep 5, 2005 | 11:23 PM
badkarma38's Avatar
Does anybody on here have experience with CAD design? Found a company that will fabricate a custom CAI. I just need a good drawing.
Old Sep 6, 2005 | 12:09 AM
Juggernaut_150's Avatar
What is the link for the thread on modding the 4.6 intake?
Old Sep 6, 2005 | 12:31 AM
badkarma38's Avatar
Modding the intake on the 4.6 is in the aftermarket section.
Old Sep 6, 2005 | 12:53 AM
BalogUK's Avatar
yea, the side chambers are sound baffles- since there are already holes in the bottom of the chambers for water evac- i'd assume that you'd just lose the sound deadening- dunno what size/number of holes penetrate to the baffles, but you'd need to obviously seal those to prevent and particles, crap coming into the intake... to the custom fabrication; wouldn't they provide the drawings for it? it would need to be pretty dang precise, engineering to avoid throwing codes (ie all the r&e on airforce1, airraid, etc..)
btw, i run autocad (architect) a remember seeing maybe a couple others with cad as well
Old Sep 6, 2005 | 05:04 AM
ieee_raider's Avatar
http://www.ford-trucks.com/forums/sh...d.php?t=397152
Old Sep 6, 2005 | 09:11 AM
kd4crs's Avatar
You would be drawing hot air in from the engine compartment instead of cool air from the fender. You would also lose the sound deadening.
Old Sep 6, 2005 | 11:31 AM
HotLap's Avatar
bad....you hit it right on - they are sound baffles and do cause uneeded disruption of the airflow. I have the AF1 on my 5.4 (been great for me!!) but on my Lincoln LS V8 Sport - it had the same baffles on the intake tube and what I (and a lot of other owners) did was to cut off the baffles, cut out a cover piece from the baffle and glue it on using clear RTV. Worked great and did seem (butt-o-meter) the help the stock intake.....however, if you are eventually going to go with an aftermarket CAI - I'd probably not cut up the stock intake tube as you may someday want to reinstall it (warranty work, selling the truck, etc.).
