Build Date
Old Sep 4, 2005 | 10:05 PM
golferdude1971's Avatar
Build Date
How do I go about finding the build date on my 05 f150?
Old Sep 4, 2005 | 11:35 PM
deltascrew's Avatar
the tag on the drivers door jam should tell you the month and year
Old Sep 4, 2005 | 11:41 PM
deltascrew's Avatar
it will look like this
the build date is in the top left corner
Old Sep 5, 2005 | 01:13 AM
If you still have your window sticker it's printed on there....
Old Sep 5, 2005 | 01:20 AM
ErnScott's Avatar
I thought this was strange. My door tag indicates a 08 05 build, but my window sticker shows it as 07/25/05
Old Sep 5, 2005 | 01:31 AM
BalogUK's Avatar
it is also embedded within your vin number about mid way thru...if you go to the FORD owner site they split up the different parts for you.
http://myford.fordvehicles.com/Stora.../popup_vin.gif
Old Sep 5, 2005 | 01:42 AM
asinatra's Avatar
That might be order date
Old Sep 5, 2005 | 10:48 AM
jpdadeo's Avatar
How to read a VIN
1st character- Identifies the country in which the vehicle was manufactured.
For example: U.S.A.(1or 4), Canada(2), Mexico(3), Japan(J), Korea(K), England(S), Germany(W), Italy(Z)
2nd character- Identifies the manufacturer. For example; Audi(A),
BMW(B), Buick(4), Cadillac(6), Chevrolet(1), Chrysler(C), Dodge(B),
Ford(F), GM Canada(7), General Motors(G), Honda(H), Jaquar(A), Lincoln(L), Mercedes Benz(D), Mercury(M), Nissan(N), Oldsmobile(3), Pontiac(2or5), Plymouth(P), Saturn(8), Toyota(T), VW(V), Volvo(V).
3rd character- Identifies vehicle type or manufacturing division.
4th to 8th characters- VDS - Vehicle Descriptor Section. These 5 characters occupy positions 4 through 8 of the VIN and may be used by the manufacturer to identify attributes of the vehicle. Identifies vehicle features such as body style, engine type, model, series, etc.
9th Character - The check digit "character or digit 9" in the sequence of a vehicle identification number (VIN) built beginning with model year 1981 (when the 17 character digit format was established) can best be described as identifying the VIN accuracy.
A check digit shall be part of each vin (since 1981) and shall appear in position
nine (9) of the VIN on the vehicle and on any transfer documents containing
the vin prepared by the manufacturer to be given to the first owner for purposes
other than resale. Thus, the vins of any two vehicles manufactured within a 30
year period shall not be identical. The check digit means a single number or letter
"x" used to verify the accuracy of the transcription of the vehicle identification
number.
After all other characters in the VIN have been determined by the manufacturer
the check digit is calculated by carrying out a mathematical computation
specified. This is based on vin position, sample vin, assigned value code,
weight factor and multiply assigned value times weight factors. The values are added and the total is divided by 11. The remainder is the check digit number.
The correct numeric remainder - zero through nine (0-9) will appear.
However, if the remainder is 10 the letter "X" is used to designate the check
digit value/number.
10th character- Identifies the model year. For example: 1988(J), 1989(K), 1990(L), 1991(M), 1992(N), 1993(P), 1994(R), 1995(S), 1996(T),
1997(V), 1998(W), 1999(X), 2000(Y)------2001(1), 2002(2), 2003(3)
11th character- Identifies the assembly plant for the vehicle.
12th to 17th characters- VIS - Vehicle Identifier Section. The last 8 characters of the VIN are used for the identification a of specific vehicle. The last four characters shall always be numeric. Identifies the sequence of the vehicle for production as it rolled off the manufacturers assembly line.
Old Sep 5, 2005 | 10:52 AM
ErnScott's Avatar
Could be. But I took the truck home on 8/10.
I'm just a bit suspicious regarding the date on the door.
Old Sep 5, 2005 | 11:05 AM
JJG052590's Avatar
Banned
Where is it on the window sticker I'm staring at mine and see nothing..
But it says Method of Transp. RAIL sweet it's a railroad car! haha
Old Sep 5, 2005 | 11:56 AM
silverbullet5.4's Avatar
If it was transported by rail, it was done by Norfolk Southern, the railroad company I work for, Ford is our single largest customer. I personally have seen carloads upon carloads of F150s moved.
Old Sep 5, 2005 | 12:02 PM
JJG052590's Avatar
Banned
She was born in Dearborn Wisconson I believe thats where it is! But that's awesome
Old Sep 5, 2005 | 12:53 PM
Look in the bottom right hand corner of the window sticker -- there should be a long series of numbers and letters, the last (6) of which should be the date (mo/da/yr) your vehicle was manufactured.
Old Sep 5, 2005 | 02:54 PM
JJG052590's Avatar
Banned
Sweet 02/03/05 but I've only got 550 miles on her..
Old Sep 5, 2005 | 04:32 PM
TMMull's Avatar
You can call your local dealer and have them run an Oasis report, it will give you the day, month and year. Or you can go to WWW.flatratetech.com and ask in the oasis message forum.
