Oil Pan Plug Torque???
Anyone happen to know the torque for the oil plug on a 2005 5.4 3V??? My owners manual doesn't say. Also, anyone know a good place to buy Ford manuals? I would like to pick up a complete set for my truck.
KC-10 FE out...
KC-10 FE out...
I've been around vehicles my entire life... That said, my truck a 2005 Lariat, has the absolute most idiotic location for an oil filter I've ever seen. This is the first time I changed my own oil since the dealer pissed me off something fierce on my last oil change. Imagine my surprise when I find that the oil filter is next to impossible to change without making a total mess. The as$holes actually built in a spillway for the mess they knew you would make when changing the oil. Instead of mounting it straight up n down its mounted at a slight angle right under a pulley. What the ***** where they thinking??? Why the idiots just couldn't mount it near the drain plug is beyond me. My dad's 2004 F250 5.4 has the filter near the plug. Sh$tty engineering just irritates the ***** out of me.
I switched to Mobil 1 5W-20. Mike Troyer recommends M1 over Castrol so I'll see if its any good. I hope its as good as advertised, it costs double what the syn-blend sh$t costs.
KC-10 FE out...
KC-10 FE out...
yeah man that thing is a pain, its a lot easier to do from underneath the truck, if I was taller or had longer arms id probably be able to do it from up top the truck under the hood but luckily i have a lift available to me so its not a big deal, shouldnt really be anyways if one is gonna get under the truck to drain the oil anyways just get back under there to get the filter.
I'm getting a remote oil filter kit after changing the oil myslef for the first time. Any suggestions to where I should mount this thing??? I've never run a remote filter before but unless I get e-fans, this will be a MAJOR pain in the as$ every time I change my oil.
A friend of mine is a USAF vehicle mechanic. He recommends that I runs full synth oil. He also said that instead of doing a full oil change every 5000, change the filter and approx 1 qt of oil every 5000. He said the primary benifit to full synth is extended change intervals. Any comments on this???
KC-10 FE out...
KC-10 FE out...
Originally Posted by KC-10 FE
...He also said that instead of doing a full oil change every 5000, change the filter and approx 1 qt of oil every 5000...
your welcome on the torque specs...
I dont have a problem with the oil filter location, or making a big mess.
Not flaming you at all, just like to agree to disagree.
I think its great that I dont have to jack up the truck to get at it.
I wonder what the price of a quart of motorcraft 5w20 will be after the price of crude oil catches up.
