Window wont roll up!!!
Old Sep 3, 2005 | 11:32 AM
HHIFX4's Avatar
well i got in my truck yesterday morning and rolled my windows down and heard some kind of pop in the passenger side door and now that b!tch wont roll up! so i took it to the dealer and they have to order some part that wont be hear till thursday. so now i have to figure out how to get my window up, does anyone know how to take the door panel off and get to the window so i can maybe pull it up and either tape it off or wedge something in there to make it stay???
Old Sep 3, 2005 | 04:00 PM
HHIFX4's Avatar
seriously nobody knows how to do this
Old Sep 3, 2005 | 05:16 PM
RockyJSquirrel's Avatar
Sounds like it should be a warranty item. Did you ask the dealership service guy to see if he could roll it up for you until Thursday?
OTOH, door panels are usually pretty easy to remove. Ford thankfully quit using those PITA one-way clips to hold the door panels on (you know, the ones that ALWAYS break when you pull the panel off). Both my '94 Ranger and '02 F150 have hooks molded on the inside of the panel. You remove 2-3 phillips screws and slide the panel up and off. I would assume the new trucks use a similar design.
Old Sep 3, 2005 | 05:32 PM
Hotboy8055's Avatar
The same thing happened to me. One of my friends works at my dealer, and he told me all they did was tap on the motor and it rolled up, and it's been fine ever since. As far as taking the door apart, the dealer did it. I think they never did take the door panel apart anyway, I think they tapped with the door panel on, I don't know but you can try that to see if it works for now. Hope this helped you.
