Anyone got a tape measure and 2 mintues?
I'm stuck in the office and I need to know the dimensions of our hoods. Anyone care to help a sarcasitic jackarse out? How big is that 'mo 'fo, roughly?
About 66" wide (tip-to-tip) at the widest part of the hood up by the cowl.
About 36" long at the center of the hood from the top edge of the grill to the back edge of the hood near the cowl.
The hood measures approximately 64" across from fender to fender. It measures anywhere from about 41" from it's longest to 37" in the center from the grille to the part where it meets the windshield wipers.
The dark side is going to lay the smack down if you abuse the power. Try finding this info in a thread... if it already exsists in this forum I'll send you a crispy $1 bill.
ok ok one of you is enough on here huh?
No, I could use the help with the beat downs, but they must be just. This info wasn't out there... but the relentless amount of "what MPGs do you get" and "what's the largest tire that will fit" and "what oil..." threads need more people to beat them down. And ludicrous posts like "should my airbag have gone off" also need smacking around (although your posts can be reported for offending someone then removed...
So carry on, just ensure they dzerv the typed lashing!
). So carry on, just ensure they dzerv the typed lashing!
