A slight problem in my suspension?
Over about the past two months I have been experiencing this crazy squeak in my front suspension.
It happens in two different scenarios. 1) Driving on any road with a bump in it or a sewer for example. (only when the bump or sewer are very bumpy) 2) If I am in the driveway and decide to put it in reverse it will squeak as I let go of the brake to get out of the driveway.
I was going to take it in today to the service department but decided I would ask opinions first. Is this something that can be fixed in your opinions? Has it ever happened before to anyone? Anyway, let me know.. I appreciate it.
Originally Posted by asinatra
you sure its the front, my rear squeaks like a bitch if i dont lube it every now and then
i am 100% positive it is the front because I took it over a speed bump to test it and the front squeaked as I passed over it with the front wheels.
It isn't very bad though.. it is annoying enough to the point where I just want it to stop because I am the only one that pays attention to it and hears it.
My truck squeeks when I put it in gear coming out of my driveway also. I drive the truck once a week so I figured it was that. But after I drive it if I pull over and start up again there is no more squeek. Im just going to swap out the brake pads soon.
Originally Posted by freekyFX4
My bed rattles and squeaks like a bitch...but hey, it's a truck!
Try some white lithium spray grease. It’s clean and easy to use and it’s designed for all metal-to-metal applications. It sprays on as a liquid, penetrates tiny crevices, and then sets up as a grease & stays put. It’s good stuff
thanks all for your replies...
im going to head over to the dealership right now and i will let you guys know whats up.
i dont have a daystar so there is nothing that they can blame it on. unless it was my exhaust or window tint that caused my suspension to squeak. :O
Found my squeek! The three nuts on the top of my shocks had woorked loose and the Daystar spacer was squeeking. Tightened up and no more squeek. Question is what is to stop them from loosening again? Anyone else have this problem? When tightening they dont get real tight before the whole bolt starts to turn. I didn't do the install so I not sure if there is something wrong.
