how to remove stickers on visor
Old Aug 20, 2005 | 07:58 PM
rj28racer's Avatar
any tips on removing stickers on visors. Don't want to mess them up by just ripping them off. thanx
Old Aug 20, 2005 | 08:06 PM
Rockpick's Avatar
Moderator &
Definitely try searching this one... this has been discussed OODLES of times.
Old Aug 20, 2005 | 08:07 PM
kd4crs's Avatar
I think I read where someone removed them with heat and careful peeling. I would try a hairdryer before moving up to a heat gun or other drastic measures.
Old Aug 20, 2005 | 08:15 PM
RobNY's Avatar
Heres a link from a quick search
https://www.f150online.com/forums/sh...light=stickers
Old Aug 20, 2005 | 08:23 PM
rj28racer's Avatar
sorry to bother you
Old Aug 20, 2005 | 09:04 PM
RockyJSquirrel's Avatar
Hairdryer for the ones on fabric. I haven't found any solutions for the ones on the plastic vanity mirror covers.
Old Aug 20, 2005 | 10:40 PM
asinatra's Avatar
I park outside, 110F summers + Black Truck = Very easy to pull off the airbag stickers.
I did this about a year ago, you could still see slight markings of the outside of the stickers. I didnt use goo-gone or any solvents, i just let it be and it is now gone.
Old Aug 20, 2005 | 10:51 PM
lrhogfan's Avatar
Originally Posted by rj28racer
sorry to bother you
Maybe he doesn't exactly know the answer, but knows a good place to look for it. Sounds like was trying to help point you in the right direction. If you have a question, sometimes it is best to search and see if someone else has had the same question once before.
Remember, it is usually better to add to an existing thread than to create a new one, especially when the topic has already been covered.
Old Aug 21, 2005 | 01:42 PM
Thayer's Avatar
The hairdryer method works great. Just take your time and keep the heat right at the edge where you're peeling. Mine came off easy but left a little shadow behind but that's almost gone now.
Old Aug 21, 2005 | 07:32 PM
ThumperMX113's Avatar
The best way to do it is to remove them as soon as you buy the truck so the fading won't be as bad, if any.
Old Aug 21, 2005 | 09:34 PM
ErnScott's Avatar
hairdryer
5 minutes to remove all 3 stickers...ever so slight fraying of the material underneath...but after removal use the back of some duct tape and press on the area around the now-removed sticker. Matches up the "fraying" perfectly.
Old Aug 21, 2005 | 09:40 PM
rj28racer's Avatar
Thanx for your help, the search is slow and not as much fun, and beside what would the senior members do!!
