Lowering FX4 in back, Heavy Payload ubolt?
Sup. I'm planning on lowering the back of my Scab, 133" wb, FX4. I wanna take out my 2" blocks. I'm looking at 2wd ubolts, they 2 different ones, regular and Heavy Payload. So...how do I know which ones to get? I'm thinking Heavy Payload, because I got the bigger axle. Any ideas?
Originally Posted by FX4&EXCURSION
I'm thinking about doing this myself. So all I would need is the regular payload 2WD U-Bolts??
I lowered mine by installing the Ground Force 2" drop shackles. It wasn't too hard to do and the kit comes with the pinion angle shims in case you need them.
Ground Force
FX4&EXCURSION,
I got them from Summit Racing. They were around $96.00, I think. You may be able to find them for a little less somewhere else though. It is a high quality kit, the shackles are finished and painted, and it has the shims which I ended up needing to put in. I'm very happy with the results. Don't forget to grease the bushings and bearing surfaces of the shackles and spring mounts, otherwise they will squeak like crazy.
Thanks!!
FX4&EXCURSION,
FX4&EXCURSION,
Yes that is the right kit, part number GRF-91200. It was $91.64 delivered. They even included a nice Summit Racing hat. The drop is adjustable. The shackles have a hole for 1" or 2" drop. I went with the 2" drop on mine and with no load the rear sits 1" higher than the front.
