Help lowering my 05
Originally Posted by rm328
I installed some 2" DJM shackles I need shims to stop a vibe. Does anybody know what degree shims I need? DJM website says they sell 2, 4, and 6 degree shims and I don't know which ones I need.
Just asking questions here, what's the difference with just removing the 2 inch blocks and swapping out the 4 wheel drive U-Bolts in the rear with 2 wheel drive U-Bolts as opposed to doing the shackle kit? Does one benefit over the other. Seems cheaper to purchase the U-Bolts you need and call it a day. Just trying to learn more about this!
Correct
Originally Posted by SoundPer4mance
on a 4wd all you have to do is take the blocks off, on the 2wds there are no blocks. but who knows what the U-bolts cost from the dealer, unless you get some universals.
from a traction standpoint the 4wds should remove the blocks, esp if NEW ubolts are only $32 a set, thats a good deal. no messing with pinion angle (much). block removal is the way to go on 4wd
Thanks Bob!, and Thumper thanks for the awesome compliment! Man, that black is a labor of love, let me tell you. High maintenance, but to me well worth it! Black on black rocks. I've been following your threads about your truck issues, and want to wish you luck on whatever you do. Hopefully you will stay in the Ford family!
